Old 03-25-2003, 06:16 PM
Darius2250's Avatar
Darius2250 Darius2250 is offline
4 Certs and Climbing
Steering arm issue
Hello all you technical mini rc repair persons.
has anyone else seen an issue with the steering control arm raising up when you go to turn and then not actually turning the wheels? if so how did you fix it? It seems to be riding up on the pin that is attached to the wheel spindle.
Thank for all you help
Shen Qui Wei - Honda Civic ---RIP
R/C Chassis - Nissan Gloria--- going Strong
MS - Honda 2000--- in process....
Old 03-25-2003, 07:20 PM
JC_focus_ZX3 JC_focus_ZX3 is offline
Send a message via AIM to JC_focus_ZX3
Only time I seen this on one of my cars, was when the front was not snapped together properly.
I noticed ofter taking the front end apart, a LOT, that the latches get quite loose and the top will pop up just a tad.
I would suggest putting the screw back in to hold the front top down again, thats what I had to do.
Old 03-25-2003, 07:45 PM
Darius2250's Avatar
hmmm , maybe I will try taking it apart then, and reseating everything
Steering Trim Issue buzzy XMODS 2 02-14-2004 10:31 PM
NEAT! Bushing for Steering Arm MST3KPIMP Atomic Z-Cars 2 02-13-2003 12:34 PM
Re: steering arm and spring HUN25 Bit Char-G / MicroSizers 2 01-14-2003 04:50 PM
