03-25-2003, 02:32 PM
charge dual bat easily + better range
all you need is a $.99 part from radioshack
http://www.radioshack.com/product.as...5Fid=270%2D401
you can insert this without solder if you are tricky. the only other equipment you need is another battery and a piece of thick cardboard(or any other insulator)
03-25-2003, 02:38 PM
State Property
..is that what u used to put 3 batt.in a controler?..how much further range does that give u?..and 1 more question did u ever get the email i sent u?..
03-25-2003, 02:39 PM
hogjowlz,
Are you just adding a third cell to the controller here? I did a three-cell mod to my 2-speed controller and did not see any improvement in range. Are you experiencing big improvements in range with 3 AAAs?
hue35
03-25-2003, 02:44 PM
ya the tomy controllers are crap. i like the "turbo blaster" but ya even after putting a 2foot telescopic antenna and adding a 3rd bat i still got crap range.
so for tomy controllers this mod will only work for charging a dual battery car.
in a clone controller you should see a range increase.
03-25-2003, 02:49 PM
So, are you running a booster car with a clone controller somehow, or are you just living with crap range on the 2-speeder?
03-25-2003, 02:57 PM
ya. my 2 speeder ripped through its pinion and idler gears anyhow so i put her away for a little while.
tomy chassis with a clone pcb is nice. great range great handling. i miss my turbo blaster tho.
hehe
