Old 03-21-2003, 03:49 PM
soggyrice.mMmMm soggyrice.mMmMm is offline
Question Does 49 Mhz really go further than 27 Mhz?
nt
Old 03-21-2003, 04:02 PM
NoPropMan's Avatar
NoPropMan NoPropMan is offline
{{ x | NO CARRIER
In my experience, yes. 49 MHz Bits and MicroSizers have a greater range than their 27 MHz counterparts.
However, in my experience the 57 MHz Fairlady set has great range as well. I have heard from many others that they do not get good range at all with 57 MHz.
I think a lot depends on interference. All I can say for sure is in my case, 49 MHz yields a much greater range than 27 MHz.
Old 03-21-2003, 04:09 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
its easier for a higher frequency to travel through the air hence 57 will be stronger than 27 at a given distance if both have the same power driven to them.
Old 03-22-2003, 11:51 AM
SlowbutCourious's Avatar
State Property
...i would say that 49mhz is my fav.i get about 25 ft or more...my 27mhz at the most 15 ft...my 57mhz gets $#!*y range 6 ft.tops!..
27 mhz vrs. 49 mhz or is it Regular vrs SE Sleeping911 ZipZaps SE 4 08-13-2004 10:14 PM
What's the best Mhz to run with... bloodyroots Bit Char-G / MicroSizers 8 05-05-2003 01:59 PM
02 MHz and other odd MHz noxorc Bit Char-G / MicroSizers 3 02-23-2003 06:49 AM
35mhz crystal worked on 27 mhz transmitter ejaf ZipZaps 3 12-11-2002 09:30 AM
range of 27 MHz versus 49 MHz gRC ZipZaps 12 09-30-2002 07:33 PM
