Go Back   TinyRC.com > 1/64 and Smaller > Table Top Truck Trials (TTTT) > TTTT Gallery
Old 03-20-2003, 01:17 PM
fastboy fastboy is offline
im a micro daddy...
Send a message via Yahoo to fastboy
new truck
ok just finished my 2nd truck,a unimog...took about 30hrs to make in total from scratch.
uses 145mah li-poly cell,40mhz jst reciever,micro servo,7mm pager motor and my homemade gearbox again,reduction 1:190
again the chassis is just plain flat brass plate,no tubing.
servo,reciever and batery is in rear,speedo in cab and motor slung under chassis,
dave
File Type: jpg green unimog and 5ton man prologue.jpg (279.4 KB, 697 views)
Old 04-25-2003, 10:19 PM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
what front axel did you use? any pictures of how small the li battery is?
Old 04-26-2003, 04:31 AM
im a micro daddy...
sorry arch its in truck and its all sealed,all i can say is its much smaller,its very flat,if you wanna make say a unimog it makes it sooo much easier,but you do need a special charger for them
dave
Old 04-26-2003, 09:48 AM
arch2b's Avatar
whats that poping up throught the roof hatch....the pot? front axel...pre made or custom?
btw- it looks nice
Old 04-26-2003, 09:52 AM
im a micro daddy...
yeah thats the pot for adjusting the speedo,front axle is homemade,i did put some pics of it on another site
dave
arch have you seen my other truck,the landrover 1 ton..its even smaller than the mog
dave
http://www.fastboy.pwp.blueyonder.co.uk/page2.htm
Old 04-26-2003, 10:25 AM
im a micro daddy...
arch,heres some better pics of the landrover 1 tonne on my course,paint jobs lousy tho,i used acryllic paint for the cab..handpainted,big mistake.
dave
Old 04-26-2003, 10:26 AM
im a micro daddy...
http://www.fastboy.pwp.blueyonder.co.uk/newtruck.htm
dave
Old 04-26-2003, 02:57 PM
arch2b's Avatar
thats some impressive work there fastboy! the gearing alone would make my head spin....
Old 04-27-2003, 03:33 PM
Landy Man Landy Man is offline
Fastboy
Where do you get your gears and Li-poly batteries in the UK? I am struggling to fit 1/3 AAAs in my design and could really do with something smaller.
I like the action shots of the Landrover, nice course, am I right in thinking that the wheel articulation is all achieved at the front axle? This may be the way I end up going too, there's not a lot of room at the back for everything.
Do you have the name of the modelshop that you got the model from?
Thanks
Landy Man.
Landy Man
Old 04-28-2003, 03:29 AM
im a micro daddy...
landy
i get all my parts from peter in germany(2 days shipping at about £2 postage!! excellant.)
i dont use normal cells i use li-poly cells,you only need 1 cell at 145mah,very small and thin,gives you more room to work in.
in my landrover i actuall had enough room in the back to get another reciever in if i wanted
email me and i will give you a list of parts i used from germany
dave
fastboy@blueyonder.co.uk
Old 10-07-2003, 11:26 PM
Comrade_Boris's Avatar
Confirmed: Lost In Fog
ok, for some strange reason the pics on your site don't show up...would it be posible to post them here?
-Andres
Old 10-08-2003, 11:30 AM
im a micro daddy...
try here:
trucks
and here
dave
Old 10-08-2003, 01:48 PM
ok, that worked............wow, that must be hard getting accross the vertical logs....i'd probly fall between them and fall over..............ya, im getting an opel "blitz" and a 5ton somthing or other (see atached pic) .....ill post pics when they arive.........
-Andres
Losi 1/36 Micro-Desert Truck arch2b Micro-T General 2 11-11-2007 06:18 PM
xmods monster truck ts185r XMODS Mods and Projects 10 02-20-2006 03:40 PM
Xmod Evo Truck HD Dogbone Mod CinnaBun XMODS Mods and Projects 0 02-03-2006 10:07 PM
How to Build a 1/87 Scale RC truck a.k.a.TTTT Overlander TTTT 445 02-25-2004 06:15 PM
