Old 03-19-2003, 07:33 PM
zot zot is offline
Send a message via AIM to zot
Question Hi! A question for Panther G owners.
Hi all, thank god I found a place to read about combat digi-q in English. Well I just ordered my Pather G from HLJ, sorry no Frys in NY. Now I just have to wait for it to get here...
I had a quick question for any pf you Panther owners out there... How wide and long is the hull? How much of this is the track?
The reason I ask all this... I think the chassis would make a good start for a Hetzer and I need to get an idea of the scale the hetzer would be on the digi-q chassis. Then I could find out if any of the normal scale models would be of any use. (Sculpting the gun mantlet would be such a pain...) Since the turret doesn't move on its own, why not?
Ah, for some plasicard and a dream.
Sean
Old 03-20-2003, 03:40 PM
Napalm_Guru's Avatar
Napalm_Guru Napalm_Guru is offline
Wanna Drag??
Scroll to the bottom to see the Dimensions:
http://www.tinyrc.com/forums/showthr...&threadid=9004
"Going to war without France is like going deer hunting without an accordion. You just leave a lot of useless noisy baggage behind.
-Jed Babbin
Old 03-20-2003, 04:42 PM
zot zot is offline
Thank's for the info. I read that a few days ago and completely forgot about it. From that info, I pretty much figure a Hetzer would be around 1/79th scale. (The width is 1/73rd and the length is 1/86th, so I'll settle on the average.)
That means I'll have to make it 2.65cm tall and 7.9cm long (including the barrel), but that's if I keep it exactly in scale. I'll prob make it super-deformed like the actual tanks. The good news... the 1/76 scale Esci Hetzer may be of some use.
sean
Old 03-20-2003, 08:09 PM
Wanna Drag??
You can get models close to that scale, but if you switch them you are going to loose a lot of durablility because they use softer plastic. It does not sound imposible to get the pcb and other stuff in, but the charging reciever and Damage LED might be a pain.
Your probably going to have to cut up parts of your tank shell to transplant the IR recieving plate.
Good Luck and please keep us posted!
-Jed Babbin
Old 03-20-2003, 08:20 PM
zot zot is offline
I know the plastic won't be as durable, but I'm not planning on dropping it anytime soon once I make it.
The biggest thing holding me back is trying to figure out how to do the Damage LED as Hetzers didn't have any copula or round entry hatches on the upper deck. I'll figure something out to hide it. Actually all the IR stuff will be a pain to figure out.
I plan on building the super structure using plastic card and not an actual scale model kit. So I'll have a lot of flexibility there. I'll use parts from that to detail it up and use some of the pieces from the plastic kit I can't create with plastic card.
I just need to get my Panther and a Hetzer kit to see if the project is even feasible. Right now I don't see why not. If I do it, I'll keep every body posted.
Sean
Question For Fet Se Owners bdnunchaku ZipZaps SE 4 12-02-2004 03:31 AM
Tureno Question. Please read Tureno owners!!! MicroSpeed Bit Char-G / MicroSizers 17 03-02-2004 03:54 AM
question for xmod owners. pavel XMODS 8 10-18-2003 05:34 PM
Question for Bitchar-G Supra owners! heuerfan Bit Char-G / MicroSizers 1 10-10-2002 02:30 PM
