03-17-2003, 01:33 AM
Perfected Bit Modder
RMYC's Lighted Antenna Mod
here is a mod i did on my 1/28 mini-z..
some one should try it on a multi cell bit
i used a smt led... and thin enamel coated copper wire
03-17-2003, 01:34 AM
up close pic of the smt
03-17-2003, 01:43 AM
Wide Open Throttle
hehe.. looks like a little lightning bug.
very nice.
03-17-2003, 05:28 AM
Check that thing out! Very cool!
If that's reproduceable, you should post the mod, because I can see lots of people doing that one!
03-17-2003, 10:16 AM
umm... didnn't undrstand that.. but any ways... this is my mod a have done ,but beacuse i had only 1 smt led ( the other burntout when desoldering) i try i't on my mini-z.
i soldered thin copper wires( kinda like the steering wires ) to the SMTled andsuper glued the led to the tip of the antenna. cause the wires are very thin, i wrapped the aroung the antenna and into the car. it's fairly easy once you sand off the enmel coating on the wire and solder it on the SMT-led
aight then
later
03-17-2003, 06:30 PM
Can you use a Fiber Optic light cable as an antenna
03-18-2003, 05:15 PM
Chief Propeller Head
no, you need something that contduct electricity for an antenna. fibre optic cable is a type of plastic.
ph2t.
