Old 03-15-2003, 10:24 PM
isk8blind's Avatar
isk8element too.
Lightbulb help needed with makin a bit helicopter
im thinkin about makin a bit helicopter but how would i make it turn ? i know how ill me makin the helocopter body and i need to make it realy light so itll go in the air but turnin is hard. any help will be apreciated
2 BCG nissan fairladyz
2 MS sport honda s2000
1 LXX auto modellista booster
2 ZZ yellow &black honda civic
and 3 clones & a pcb.
Old 03-15-2003, 10:45 PM
ViNsAniTy ViNsAniTy is offline
Send a message via ICQ to ViNsAniTy
sounds like a great idea, but there is a lot of physics that go into a helicopter and I think it will be pretty hard to make from scratch...plus I think you'll have a hard time finding a small motor that is powerful enought o lift the whole assembly...
I believe turning on a helicopter is done with thel stabilizing propeller on the tail of the helicopter...good luck!
Old 03-15-2003, 10:48 PM
Silent_NightR34's Avatar
Got Mini-z?
well u could probaly use one motor to spin the blade(3.8)...then 2 more motors one to move the helicopter blade from side to side and another to make it go forward by making the blade lean forward or backwards(1.0s)...the u might need another motor at the back with a smaller propeller...each time u turn the motor wopuld spin the other way(2.6)...4 motors 2 pbc boards a good chassi and body a modified controller and u got urself a helicopter..to many motors tho..might need alot of batterys too..preety possible tho
Old 03-15-2003, 11:27 PM
isk8blind's Avatar
isk8element too.
heres my proto type drawing. 3.8 for the top blade turbo motor for the side blade.the pcb is behind the chasis and batterie. but i think ill use 2 150mah batteries insted of one stock
Old 03-16-2003, 05:56 AM
MadMicroDoc's Avatar
MadMicroDoc MadMicroDoc is offline
TinyRC Champion Racer
Talking sweeeeet
ive been wondering when someone would bring a nit-helicopter to reality ! I
m pretty sure ure goint o need more than one 3.8 motor on the top, maybe you should thnk of a way to integrate 2 props on the top of its chasis, u should also use layman;s batteryss(for good weight distribution) the only problem is u would have to make battery holders for them and not solder them, and make a chrger.
seems like this could work ! im intrested in seeing the body of the a helicopter anyone is using!
Old 03-16-2003, 10:26 AM
dustn's Avatar
dustn dustn is offline
Poor Student
Send a message via AIM to dustn Send a message via Yahoo to dustn
Ok, a helicopter would be interesting, but very hard. At the least you will need a full r/c system with micro components. To see what this guy did, go here. Pixel Helicopter
Fight Crime <--> Shoot Back
Old 03-16-2003, 02:33 PM
isk8blind's Avatar
isk8element too.
ok now im thinkin to try and get it in the air id put a 3.8 in the front then a 3.8 at the end of the chasis then another 3.8 at the end of the tail and either 2 150mah batts or 3 210mah batts
heres a pic of it
Old 03-16-2003, 03:57 PM
dustn's Avatar
Poor Student
lmao...
Old 03-16-2003, 03:59 PM
isk8blind's Avatar
isk8element too.
whats lmao mean i forgot?
Old 03-16-2003, 04:30 PM
dustn's Avatar
Poor Student
well it means laughing my ass off, but that was mean. i retract it.
Old 03-16-2003, 04:33 PM
isk8blind's Avatar
isk8element too.
well it looks kinda stupid but it would be cool if it works
Old 03-16-2003, 04:50 PM
AUDI-TT's Avatar
AUDI-TT AUDI-TT is offline
XMOD AUDI TT (my wish)
it wont work if u have only 2 motors and one pcb because the blades have to be able to change their angles, although u could refrain from that problem by making the motor spin faster and slower. It wont turn if u have 2 motors either itlls just be able to lift up. i think this project is too hard and i also dont think a 3.8 will be able to lift up so many motors and batterys.
Old 03-16-2003, 08:30 PM
bwsk8's Avatar
bwsk8 bwsk8 is offline
NSX Driver!
You would defentialy need the back prop to counteract the torq.
Old 03-17-2003, 10:15 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
well it will take a lot of luck and hard work but i think this has a lot better chance than a pod racer.
hahahaha
Old 03-17-2003, 03:13 PM
Got Mini-z?
well is my idea of doing it pretty good? or is it just as lame as makeing that pod racer thingamagig
badly needed authentic bit or microsizer any frequency other than 27 mhz airbob20 Bit Char-G / MicroSizers 1 12-27-2002 09:44 PM
Bit Char G replacement parts needed, HELP! likwidplastik Bit Char-G / MicroSizers 32 12-03-2002 08:09 AM
