03-13-2003, 04:36 PM
Tiny RC Pro
Podracer
03-13-2003, 04:40 PM
how does it float a few feet off the ground?
03-13-2003, 04:50 PM
BIT PIMP
Hello? What about magic? You didn't forget about magic did you? lol
silla
03-13-2003, 04:53 PM
also the fan unit is the motor so where does the 3.8s come in?
you would need some serious power to move any fan fast enough to propel at a fast enough speed to make it cool.
my biggest question still is how you would get everything to levitate.
man i cant believe you and myself forgot about the force.
03-13-2003, 06:58 PM
Tiny RC Pro
it will have small legs of lexan to hold it up until the wings take over. The 3.8s will run the fan units!
03-13-2003, 07:05 PM
For a min I thought you were talking about Zcars. I'm interested in seeing how this turns out. If you wreck the digiq send it to me!
03-13-2003, 07:43 PM
how will the 3.8s run the fan?
i already stated this. the fan unit is the motor. i dont get how a motor will power another motor.
and to get two fans to drag all that weight that is dragging on lexan you would need to build a mini fusion reactor or something.
youd have better luck mastering the force.
03-13-2003, 11:47 PM
I come for your women
Man no offence that is the dumbest thing i have ever heard. That is impossible.
Getting out of Bits and into 1/24th scale.........
Offer me an amount for all my stuff:
- 9 bodies 2 Celicas, 1 Lancer, 1 Skyline, 1 S2000, 1 350Z, 2 RX7, 1 AM Rx7(most bodies with custom paint/decals email for pics)
- 2.6 Motor
- 57Mhz Chassis (all stock pieces)
- 1 Pull Back chassis
freakensteiner@hotmail.com
03-13-2003, 11:55 PM
Blitzer Sonic
I was really bored an made one..... sort of. It was from this set I got a while ago. I see some real potential in this though. It has a black base with 4 wheels that it's normally on. Put the pcb on the bottom, add some gears to the back, add a steering unit to the front, and maybe make the engines of the pod racer the batteries instead of the decorated one the set comes with.
03-14-2003, 12:55 AM
Poor Student
lets all keep in mind that Racer9 was the guy that was all positive that he could get a rotary-powered bit for $75... My suggestion would be to watch the movie and press the buttons on your controller for realism.
Fight Crime <--> Shoot Back
03-14-2003, 05:05 AM
Or just play the game instead!
03-14-2003, 03:02 PM
Tiny RC Pro
3.8 would run fan!  BTW I changed my mnid to use helium to hold it up!
03-14-2003, 03:28 PM
how does the 3.8 run the fan?
any fan you buy already has a motor in it. are you planning on having 3.8 power a generator to power the fan? that would be inefficient way to do this. plus most fan motors are going to be more powerful than a "3.8" and any fan that would propel that much weight is going to have a heavy voltage requirment which would mean you will need about 30batteries to run everything which will make your podracer the size of you. helium? you will need a balloon about 1000 times the size of the pod racer to lift it.
i commend you on your creativity and all but this would not work with todays technology. thats why pod racers appeared in a "science fiction" movie
03-14-2003, 03:40 PM
this fan costs 140$ and i doubt two of them would pull that much weight because you will be lugging a lot of batteries around. how you planning on steering this btw?
you would be better off making your rotary engine first.
