Old 03-11-2003, 09:24 PM
GrEenGoBlIn GrEenGoBlIn is offline
Send a message via AIM to GrEenGoBlIn
new motor?
is it possible to purchase a new motor, some how one of my motors on my tank is getting horrible power. I cant even drive the tank without it going in a circle.
Old 03-11-2003, 11:12 PM
Meltdown's Avatar
Meltdown Meltdown is offline
I had the same problem and i fixed it.
Remove the faulty motor from the pcb and out of the tank!.
Don't forget to note the polarity.Write it down!
Connect it to 2 AA penlite batteries (3volt) and let it run free for a few(4) hours.
Then put it back in. It worked for me.
Old 03-12-2003, 01:39 PM
beetyii's Avatar
beetyii beetyii is offline
Mr. 100%
Take both motors out of your tank and give them a free run for 2 - 3 hours at 2,4 V. That´s it.
beetyii
Old 03-12-2003, 01:52 PM
Meltdown's Avatar
Mmm, better try the faulty motor first or you could end up with the same problems you had before.
The trick is to balance the 2 motors.
The "good motor" is already running at it's top speed. The faulty one isn't so you have to balance the two by "running in" the faulty one first.
Old 03-12-2003, 02:12 PM
beetyii's Avatar
Mr. 100%
You allways have to run in a new motor - if you don´t you never get the best out of it. The brushes would thank you for a run in before trying what your tank is able to do (climbing for example) - if they only could speak...
You can ruin a brand new motor by first climbing without a run in !
Ruin means not that it wouldn´t work anymore but the best is gone for ever...
beetyii
Old 03-14-2003, 10:19 PM
thansks for all the comments, but the motor isnt new, I have had the tanks for a few months now and thie problem just occured. Could it be the same problem?
Measuring Motor RPM backtrack9 XMODS Science 9 01-12-2004 05:00 PM
(LONG)Another Motor To try "Nurelco Mustache Trimmer" Cyfiawnder XMODS Parts and Hop-Ups 25 12-19-2003 01:01 PM
