Old 03-04-2003, 09:13 PM
got BITS?
Motorworks charger
If I had a dual cell (50 MAH) could I do it with my Motorworks charger? Also how long should I charge it (sorry I'm dumb) Put some links if you don't want to type
Old 03-04-2003, 09:31 PM
Stridex's Avatar
Stridex Stridex is offline
Chunk
Your best bet is getting a wall transformer that outputs 9v's (NiMh) and running it through the MotorWorks stand-alone charger. I've had nothing but bad luck charging dual cells without the help of an AC connection. The charger (by itself) will work better then your MS/Bit/Clone charger, but...you'll be missing out on the true power of a dual/triple cell mod, IMO.
A religious war is like
children fighting over
who has the strongest
imaginary friend.
Old 03-04-2003, 10:09 PM
got BITS?
I don't have a soldering iron though. Any other way to put a wall jack on the damn thing?
Old 03-05-2003, 12:48 AM
Stridex's Avatar
Chunk
You'll really need a soldering iron if you want it to last. You can always strip the insulation and just wrap it around the old battery contacts, but that won't last long and won't always make a good circuit. Soldering irons are dirt cheap at RadioShack. Under $8 I believe.
imaginary friend.
Old 03-05-2003, 12:51 AM
chelboed's Avatar
chelboed chelboed is offline
Epoch's R Bett'R
9v is a bit steep for a dual cell. I use 7.5v for my 3cell cars. I usually use around 6v for a dual cell car.
car not running long, and some charger help.. tegboi Bit Char-G / MicroSizers 2 10-12-2008 09:09 PM
motor works SUCK AUDI-TT Bit Char-G / MicroSizers 20 03-06-2006 03:50 PM
8 car charger for Epochs rmelancon Epoch RC1/43 2 12-11-2002 09:39 PM
