Old 09-04-2002, 03:25 PM
Arrive2Defy
Unhappy Help Me Please!
omgomgomgomgomgomgomgomg...is goin on? i think my bit char is dead! jk.. but seriously it wont run.. maybe for like 1 inch after i recharge it. i am positive its ther bettery.. i got the 120mah those form qfm... what gives? can you fry your battery from charging too long? cuz i charge it and sometimes i forget about it untill like 5 min later... it worked fine before... i put my stock one in and it worked fine (charged it for about a min and ran it around to test it for about 10 sec) but when i put the new battery in it wont run... also the battery is SMALLER then stock and i think that maybe the recievers arent touch the battery ends. i bent the ends so they touch but i think it might be still too loose (donno why cuz it worked fine a week ago... also it runs on the charger...) HELP ME OUT PLEASE! TINY! WEGINATOR! FANMAN! ETC...
i try so hard to take care of my rc and this is how it repays me!
Old 09-04-2002, 04:00 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
Here's a few thoughts...
- Turn the car upside and run it. Does it run at all?
- Did the charge light go out when you left it on the charger for so long? If it did, then no worries...But if it was sending juice the whole time, you've probably got a fried batt.
- Recheck the fit of the battery, it should go in SNUG. If you're going back and forth with the bigger, stock battery, maybe you're bending the leads back out and not getting a SNUG fit
Good luck.
Old 09-04-2002, 04:09 PM
Arrive2Defy
Unhappy
SH!T!!!!!!!!!!!!!!!!!!!! -_________- damnit im so sad... i found a wire that had been broken (cut). the BLUE one under the circuit board. how can i fix it without buying a new one? where do i weld it to? PLEASE HELP!!!!
Old 09-04-2002, 05:40 PM
Redfire's Avatar
Redfire Redfire is offline
Just kinda burned you...
Send a message via AIM to Redfire Send a message via Yahoo to Redfire
If u have a soldering iron, you can solder the blue wire back to the flat metal piece. Its the flat thing thats on one side of the controller, its right beside where the wire antennae pops out. Do you see it?
"I won't lose, no matter what, because the prize is a full tank of gas." Takumi
