Old 03-01-2003, 03:31 PM
Overlander's Avatar
Overlander Overlander is offline
Overworked
New Micro Servo! Smallest in the World!
Some CA glue leaked into my GWS Picco servo and locked the gears together. Before I realized what had happened, I forced the control horn to spin and it broke some gears inside. A rookie mistake, but stuff happens.
So I went to buy a new servo to finish my MAN project and to my suprise, there is a newer smaller servo availble! It is a Cirrus CS-5.4 its dimensions are 20.15mm x 8.1mm x 17.7mm!
The bet part is that it does not have the little bump in the housing next to the output shaft so you can now mount it flush against a surface! It only cost $24!
_______________
I just like to build.
Micro RC for way over a decade
Old 03-01-2003, 04:30 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
That's a mighty small servo!
Old 03-01-2003, 04:32 PM
AUDI-TT's Avatar
AUDI-TT AUDI-TT is offline
XMOD AUDI TT (my wish)
cool
Old 03-01-2003, 06:22 PM
fastboy fastboy is offline
im a micro daddy...
Send a message via Yahoo to fastboy
yes i have 2 of them..called saturn and distibuted by irvine here in england..there can be a problem i think tho..its a struggle to get the servo horn thru the chassis enough as there isnt a lot of reach on the servo horn spindle which means that if you need to make your servo horn run over the chassis you will struggle.
Old 03-01-2003, 09:11 PM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
overlander- throw that in the wish list too
oops, i just looked and you have!
Old 03-02-2003, 03:01 AM
Thorsten Thorsten is offline
Nice servo ;-)))))
I use this sice in different trucks.
but ist isn't the smallest one you can get.
Actualy the smalles I know is called "NANO" and you can get it at www.mikroantriebe.de .
In a view weeks (at the end of march i hope) there is a smaler servo availible.
Less than 1 gramm and perfect to put it between the front wheel of a personal car 1/87. Its also developed by www.mikroantriebe.de
The "Nano" I use in my "Lanz-Bulldo" Traktor:
best regards
Thorsten
www.mikromodell.de
Old 03-02-2003, 03:03 AM
killer's Avatar
killer killer is offline
Proud to be Pinoy :)
:ö:
great find O! , ei! there's no need to buy a new servo if you have damaged just the gears, there are complete gear set available to replace the damaged ones, ask your LHS if they have.
-æ
hehehe
Old 03-02-2003, 01:27 PM
Overlander's Avatar
Overworked
Nevermind about the Cirrus CS 5.4!
I bought two of them and they both DONT WORK!
I tried them on two different receivers and they glitch and only work intermittently. They both tend to spin continuously.
I took one apart and found that they dont have travel limiters and thats what makes them spin continuously.
I SHOULD NOT HAVE BOUGHT THESE! but they looked nice and small.
I dont understand why they dont work.
_______________
RMYC's World Fastest Smallest 4wd RC rmyc XMODS 30 07-06-2004 07:25 PM
How To Build a Micro Speed Control From a Servo Overlander TTTT 20 05-26-2004 01:21 AM
Holy Cow!!!The world smallest CNC lathe. tonylu TTTT 1 11-20-2003 10:31 PM
This IS THE smallest r/c in the world!! Munim Bit Char-G / MicroSizers 4 01-16-2003 09:57 PM
Guiness World Record - smallest electric car Stridex ZipZaps 8 01-08-2003 08:58 PM
