Old 02-28-2003, 08:55 PM
Heat's Avatar
Heat Heat is offline
Zhuge Liang - My Idol
Reverse booster mod
how do you do it? i have a lxx charg but i think it's the same as a bit since the wires go to the same places anyways.
Old 03-01-2003, 08:18 AM
strider_mt2k
I haven't been inside a controller to know, but it should just be a matter of replacing the switch they are using (probably a normally open, or off kind) with a normall closed, or on kind.
That way it could be used more properly as a brake, eliminating the need for holding the button down all the time.
Old 03-01-2003, 09:48 AM
Heat's Avatar
well i found a site, it says to remove the two wires that are soldered to the positive and negative terminals and solder them back in reverse. but it was in german so i couldnt understand the translation so i didnt do it. just wondering if someone has an english version i can read. i seen it before just dont remember where tho
Old 03-08-2003, 01:40 AM
got BITS?
http://www.got-skillz.com/
Clcik on Mad BitChar-Gz
then click on The Modz
ZZ No Reverse Mod How to? Mr. Fisherman ZipZaps 18 04-17-2003 09:02 AM
A stupid question: Switched Reverse mod wire colors = ? frizzen Bit Char-G Mods and Projects 0 01-12-2003 10:37 PM
Does the Dual Batt Mod also work with Booster Maschine Jorgw Bit Char-G Mods and Projects 1 12-05-2002 11:44 PM
Reverse mod..while keeping reverse ZIZI ZipZaps 4 11-26-2002 05:06 PM
No reverse mod Colt45101st Bit Char-G / MicroSizers 3 11-24-2002 07:04 PM
