Old 02-27-2003, 10:04 PM
CRUMB's Avatar
CRUMB CRUMB is offline
Send a message via AIM to CRUMB
Lightbulb fully charging zipzap stack battery
the quick charge thing just doesn't work for me and all those other peak charger mods r too much so all u have to do is put the zipzap on the charger ...and wait.....when the light turns green take it off and do it again.....keep doing this until the light doesn't turn green any more and then u'll have a fully charged zipzap without all the hassle of more hardcore charging methods.
JuDgE nOt LeSt Ye Be JuDgEd YoUrSeLf
Old 02-27-2003, 10:06 PM
CRUMB's Avatar
supposed to say "stock" soryy typo
Old 03-01-2003, 11:44 AM
neutrax
thanks needed that havent been able to charge mine all the way prolly why it doesnt run as well as it did when i first got it
Old 03-02-2003, 09:57 AM
crazydave's Avatar
Garage Rocker
That is not a very accurate method of peaking your batteries.
You can use a volt meter to watch for your batteries peak.
Here the thread where I talk about it.
http://tinyrc.com/forums/showthread....&threadid=7511
I get killer punch, and really long run times, and the batteries only seem to get more consistant.
My older Zip snaps right on the clone charger base that I charge my bits on, but my newer Zip Zap is lacking the notches on the side of the chassis to hold it on. So If you have a newer one you might have to rig something up.
If you don't want all the hassle, I've found that with a fresh set of batteries it takes 3-4 min. for the ZZ's 100mah cell to fill, so you could safely get away with 4-5 consecutive charges, and be filling your battery nearly to capacity.
Crazy Dave's Crazy Car Gallery-It's crazy man, dig it.
Build a Stand-Alone AC (or battery) charger SuperFly Tips, Mods and Reviews 0 09-03-2003 08:22 PM
Battery Basics 101 Namuna Bit Char-G / MicroSizers 35 06-29-2003 09:17 PM
FYI:Motor Works (clone) charging base will charge dual and triple battery setups. Clint Bit Char-G / MicroSizers 0 02-17-2003 05:09 PM
More powerful steering for 2-cell mod? bonus: faster charging for dual battery mod Chris Bit Char-G Mods and Projects 1 11-23-2002 08:24 PM
My ZipZap now runs circles around my Bit! (dual batt success) caver01 ZipZaps 16 11-05-2002 12:22 PM
