Old 09-03-2002, 01:55 AM
cowfish_29's Avatar
yellow fish forever!
might try an airplane...?
I was just thinking about how hard it would be to make an airplane made from bit char-g pieces fly.
-First off, the battery is kinda heavy, but not too bad, it could work...
-Making the horizontal AND vertical stablizers work
-To fly any kind of distance, the whole thing would have to have crazy good range...(imagine trying to fly a plane with 5-10Ft of range)
-There would have to be a special charger
i know SOMEONE has done this, or tried, because i've seen pictures of it somewhere. If you know where they are, couldja post a link?
Old 09-03-2002, 02:01 AM
sharpshooter sharpshooter is offline
Send a message via ICQ to sharpshooter
the pictures?
http://www.palmislife.com/cgi-bin/ut...1&bpg=5&age=30
shoot to kill
Old 09-03-2002, 02:04 AM
payaso payaso is offline
BIT PIMP
Here's a pic for ya...
Old 09-03-2002, 01:29 PM
TheFanMan's Avatar
TheFanMan TheFanMan is offline
Shoot To ILL
Send a message via AIM to TheFanMan
yeah dood, it's a great idea, and I already started on it with my old 27 chasis..... hey, you could finish it with me
Custom:
Toyota Trueno
tires: soft
gear: light blue
shocks: mediums
motor: 2.2
Old 09-03-2002, 02:03 PM
Tortoise-Licker Tortoise-Licker is offline
If you are going to do it don't do what this guy did.
He took a rubber band plane and basicly converted it with bit charge bits. This is all wrong.
For a start he's using a wrong prop, the one he is using is designed to be turned by a rubber-band and when you bolt it to a char-g motor its spinning to fast to generate enough power due to the wrong angle of the blades. You can get micro props which will generate more power but be smaller.
secondly his way of controlling is all wrong.
He is using the rudder to turn the plane, why I don't know. The most efficent way would be to use small linkages to lift and lower aerolons on the main wing. This would mean if you turn one way the plane lifts one aerolon and drops the other causing the plane to roll.
If I was going to do this I would utilise a bit-char-g/bit racer hybrid. This would mean the prop is on all the time and I would use the forward/backward control to move another two control surfaces up and down ( by using another magnet and coil set) to give me pitch control. And then build a dedicated air frame around it out of thin balsa sheet and doped tissuepaper.
Old 09-03-2002, 06:51 PM
blacksabbath070's Avatar
blacksabbath070 blacksabbath070 is offline
IRON MAN OF BIT RACING
blah
Tortoise-Licker,
the guy taht made the plane must not have made too many mistakes because the plane actually flys so if he had made the mistakes you pointed out then it would have a hard time flying but the owner of the plane must have known what he is doing becuase it works great
MY NEW CUSTOMIZED BIT:
red ae86 with zipzap spoiler
carbon fiber hood
3.8 motor (well, it doesnt want to run now)
qfm springs
back wheels on front and back
8.25:1 gearing
rare earth magnet steering
Old 09-04-2002, 02:39 PM
Re: blah
Originally posted by blacksabbath070
Tortoise-Licker,
Fair enough, I knew that I might get flamed when I registered on these forums, but getting flamed after offering advice to somebody on an alternative and In my opinon (with over 10 years building rc planes and jellocopters) a better way of doing it.
Oh well
MY Custom Bit Supra
Gold Springs
Teal gears
Fury motor
Large front wheels
Soft fronts, mid rears
Custom heat sink
Whip attenna
Advanced Mike Williams Light Kit
120mh Battery
Old 09-04-2002, 04:18 PM
TheFanMan's Avatar
Shoot To ILL
I made mine out of one of those planes and the prop worked just fine, I just jammed it onto a tapedeck motor. works just fine
Custom:
Toyota Trueno
tires: soft
gear: light blue
shocks: mediums
motor: 2.2
Old 09-04-2002, 04:53 PM
hi
hello tortoise licker i wasnt "flaming you" i was jsut trying to say taht if the guy had instrucions on how to build the palne he did and if it did work then why not jsut build that one? sorry but text always seems worse then it is oh and welcome to the tinyrc forums
carbon fiber hood
qfm springs
8.25:1 gearing
Old 09-04-2002, 10:05 PM
cowfish_29's Avatar
hmm...has anyone ever seen those styrofoam planes, about the size of a whitewings glider? i was thinking that one of those might work the best...or maybe one of the larger whitewings gliders with a fuseloge (sp?) that is hollow.
Either way though, I am not gonna take a tomy car apart if it is working. If i the plane with Thefanman does not work out, i might build one with an OEM kinda cheap car, cuz they come with pretty fast motors already.
tell me whatcha think,
-nick-
Old 09-04-2002, 10:07 PM
cowfish_29's Avatar
Oh, and yes, TheFanMan, When i come over friday we can work on the plane, and I will try to bring my brothers car without him noticing...yeh think he will?
Old 09-04-2002, 10:53 PM
TheFanMan's Avatar
Shoot To ILL
probably......but snag it anyway
Custom:
Toyota Trueno
tires: soft
gear: light blue
shocks: mediums
motor: 2.2
Old 09-04-2002, 10:57 PM
cowfish_29's Avatar
I am conducting a scientific experiment. I put a piece of paper on the edge of my brothers bit char-g case. If he opens it up, it will fall out and i will know he has looked at it since i put it there. If, by friday, it is not gone, i might consider borrowing it...
heh heh...i am evil...i am gonna pay for this one i think.
Old 09-04-2002, 11:38 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Tortoise-Licker, I think blacksabbath070 misunderstood your comment to mean that the builder didn't assemble the plane correctly. I think that what you really meant is that this simplistic machine is not the best way to go about it. It's clear that you've got a great deal of knowledge on this, can you share some of your creations?
Old 09-06-2002, 03:25 AM
tr3 tr3 is offline
yeah, i would LOVE to see instructions(in english) on how to make a plane out of one of these.
airplane radio set scatmanjohn01 XMODS Mods and Projects 6 01-19-2004 10:48 AM
Smallest RC Airplane (pic) Stridex Other Tiny RCs 14 02-09-2003 10:06 AM
airplane esc was ist los? Other Tiny RCs 4 10-30-2002 07:48 PM
