Old 02-24-2003, 05:57 AM
Fourustwentius's Avatar
Fourustwentius Fourustwentius is offline
Help Me!
Exclamation I think I fried something!? I need a bit-mechanic
I over charged my dual cell S2K and now the run time is crap. like 1.5 minutes. I just left it on the charger I made from 4 AA batts. But for like 30-45 minutes! Man what a stoner move! Any ideas?
At the bottom.
Old 02-24-2003, 06:08 AM
btlmr's Avatar
btlmr btlmr is offline
TinyRC Chief
Send a message via AIM to btlmr
The fact you have runtime at all means the PCB is ok. You just need new batteries.
butler
_______________________
Size clearly isn't everything...
Old 02-24-2003, 06:19 AM
Help Me!
Nuts! I'vve got the batteries, now I just gotta get back in there. After I routed the wires through the two spoiler posts. Damnit! Well thank you for the timely response oh btw, can I use two different mah batteries like 150 and 50? Double btw, nice avatar, I love the Simpsons! No beer and TV make Homer something something.- Homer, one of the haloween episodes
At the bottom.
Old 02-24-2003, 06:25 AM
btlmr's Avatar
TinyRC Chief
I am not sure about mixing capacities. Mah. I personally wouldn't.
...go crazy?
Don't mind if I do!
butler
Old 02-24-2003, 06:39 AM
Help Me!
Ok backto two 50's. Thanks again! Do u dual cell?
At the bottom.
Old 02-24-2003, 06:51 AM
btlmr's Avatar
TinyRC Chief
I did a dual cell in another bit, but because I lowered the body and couldn't get it all to fit. It was fast though. Its in bits at the moment.
I am waiting to do a laymens mod on this bit. L3V3L1 is going to send me the cells.
I am tempted to a get a zipzap because they are bigger. More room for batts.
butler
Old 02-24-2003, 09:10 AM
chelboed's Avatar
chelboed chelboed is offline
Epoch's R Bett'R
I put a 50 and a 150 in my bB, and it worked just fine. Little longer run time than 2X50's, but not as much as 2x150's. Performance was good though. Wheelies out the yang.
Old 02-24-2003, 03:23 PM
Help Me!
I could'nt pull wheelies with my dual-cell and a 2.6, but my 3.8 is shot. Gotta clone 2.8 but it's too long.
At the bottom.
Old 02-24-2003, 03:41 PM
Lord_Nick_D's Avatar
Lord_Nick_D Lord_Nick_D is offline
I cant stop modding
if you mix different amperage batteries the total amperage of the two wired barreries will be that of the lower capacity one
so if you put in the 50mah with the 150 mah it will be only 50 mah
Old 02-24-2003, 04:01 PM
chelboed's Avatar
Epoch's R Bett'R
My clone motors have WAY out performed my 2.6's and my 3.8's. If they're too long, just sand/shave/grind a teenie bit of the button-nipply-nub off the back end of it, it'll fit. They fit mine just fine w/ a snibbit of modification.
Old 02-24-2003, 04:46 PM
strider_mt2k
Well put! A little brain salad surgery never hurt, as long as you're careful, and it works.
Definitely do not mix mah (mili amp hour rated) batteries, it's wrong and it's dumb. You should be ashamed.
Well, not really, but it works LESS well than the lower mah rated one because of electrical inequalites when charging.
Whenever possible you want new matched pairs (or whatever). Used matched ones are okay too, as long as they are the same mah rating.
Old 02-24-2003, 04:50 PM
chelboed's Avatar
Epoch's R Bett'R
I was TRYING to blow up my car when I mixed. I was pissed at it. It had the last laugh, so I was nice to it and treated it to a paire of 150's later.
Old 02-24-2003, 10:52 PM
Help Me!
Thanks, time to order some batts. Where can I get em cheap on the web?
At the bottom.
Old 02-25-2003, 07:02 PM
Flux49Mhz Flux49Mhz is offline
Lord nick's terrible mistake
Lord_Nick_D wasn't correct when he said that the current of the low bat. dominates. Of course, if you want longer run times you can mix different rated bats (one hi,one lo), like 50 and 200Ma , for example, and actually get 250Ma. You just have to link them in parralel.
Auto Modellista blue gears, 3.5 , 49 Mhz
honda s2000 ,yellow body, stock gears, 3.2, 49Mhz, electrical nitrous oxide (I will inform everyone of this invention sometime)
ultraviolet (I will inform everyone of this paint job sometime) s2000 body
Old 02-25-2003, 08:53 PM
chelboed's Avatar
Epoch's R Bett'R
One of us is not following correctly, I think he WANTS them in series for performance (speed) purposes, right?
Hired as a BIT mechanic mr0072003 Bit Char-G / MicroSizers 6 11-07-2002 12:03 AM
Entire Bit collection for Sale (Customized Bits) bitfreak Bit Char-G / MicroSizers 10 09-13-2002 07:28 PM
