Go Back   TinyRC.com > 1/24 and Smaller > Dynamite Rocket Racer > Dynamite Rocket Racer
Old 02-23-2003, 09:02 PM
misterbungle misterbungle is offline
Send a message via Yahoo to misterbungle
Looking for a Solution!!
I am wondering if anyone knows the cause, as well as the solution I am having on my DRR.
When I turn on the car and then the tx, the motor spins in reverse on it's own at full speed. Anyone know the culprit for this problem? Thanks in advance.
Old 02-23-2003, 10:32 PM
2000-redrider 2000-redrider is offline
If it's not low batteries, it could be a bad crystal.
Old 02-23-2003, 11:00 PM
neither....any other thoughts? anyone?
Old 02-23-2003, 11:17 PM
irc irc is offline
Have you tried to reset your ESC? Try to re-set your esc per the drr manual.Make sure you center the throttle trim on your radio when you do this.
" THINK FAST "
Old 02-23-2003, 11:31 PM
darn...i don't know if i still have the manual. Do you or anyone think you can scan that page and post it or email it to me? Maybe even just tell me what to do.
Old 02-23-2003, 11:37 PM
never mind...i found my manual...and that DID work. Thanks a lot.
Multicell voltage solution xxspeednplayaxx XMODS Mods and Projects 7 01-10-2004 09:07 PM
Possible Solution To Steering Inequality!!! r34 racer ZipZaps SE 11 10-07-2003 11:34 AM
SPRING Suspension solution!!!! rexdale_hacka Bit Char-G / MicroSizers 3 04-29-2003 06:06 AM
custom chassis production has started ronak26 Bit Char-G / MicroSizers 45 02-24-2003 03:18 AM
any solution for 3.0s? nrmcj Bit Char-G / MicroSizers 22 01-11-2003 05:54 PM
