02-18-2003, 12:39 PM
who has the pic of the mustang zz with the hood mod???
matt
02-18-2003, 10:34 PM
What hood mod? You mean the one that opens? Well here it is, if this isn't the one you meant sorry.
02-19-2003, 09:37 AM
yes it is
so how u do it like how u cut it out and hinge it and wat now
matt
02-19-2003, 11:14 AM
It's very easy takes about ten minutes, I used an x-acto and followed the body lines, if you snap the tip off of the blade and cut with the backside it works like a score and cuts very fast. The hinge is just two rubberband pieces, the tension keeps it closed.
Hope this helps
02-19-2003, 11:19 AM
kool
i am using a razor blade and it takes forever to cut all the way through and half the time it gets stuck in the car and then slides off and puts scratches in the hood and lights
any ideas
matt
02-19-2003, 02:39 PM
Like I said try an xacto knife, there much easier to control, and if you snap the tip off and use the backside it will dig right thru the plastic, also it's better to cut lightly and accurately then trying to cut it all the way thru.
02-19-2003, 08:36 PM
I don't understand how you got the hood to stay down with rubberbands . Can you please explain how you did it.
02-19-2003, 09:26 PM
I just glued them on, when the hood is opened it stretches them so they pull it closed, when you glue them you might want to stretch them just a little to keep the hood closed tight. It's a simple system but works quite well.
02-20-2003, 08:46 AM
ok
i found a razor blade in my closet one of those 1" ones not the retractable one which i was originally useing and the 1" one worked like a charm
matt
02-21-2003, 06:25 PM
Wide Open Throttle
that's an awesome orange color. Nice hood mod too.
i'll have to try that
02-22-2003, 12:35 PM
midgetPimp
now, this would probably work with any mini r/c prolly, right? i.e. my microsizer?
02-27-2003, 08:00 PM
2Fast2Catch
My Car
02-27-2003, 09:38 PM
cool
i gots a yellow mustang ..... i think im gonna do that hood mod
JuDgE nOt LeSt Ye Be JuDgEd YoUrSeLf
02-27-2003, 09:39 PM
how do you add the tail pipe?
02-28-2003, 02:19 PM
midgetPimp
icedragonad: please refrain from posting off-subject posts. Thank you
btw, nice muffler
