Old 02-18-2003, 11:45 AM
scottyboyfun's Avatar
scottyboyfun scottyboyfun is offline
Im a cat, miow.
Send a message via Yahoo to scottyboyfun
Extra Channel On The Boosters!
Have a look at this site!
Its in the link below in xatu's post!
So what do u lot think?
Post it!
Old 02-18-2003, 02:08 PM
xatu's Avatar
xatu xatu is offline
they say im slooooow eh?
Or, just go here, because that translator really sucks.... http://babelfish.altavista.com/babel...%2F1moreTX.htm
Old 02-18-2003, 08:39 PM
MadMicroDoc's Avatar
MadMicroDoc MadMicroDoc is offline
TinyRC Champion Racer
Question hmmm
what is the purpose of this mod ? what difference does it make on the car and/or controller ?
Old 02-20-2003, 11:29 AM
dougal's Avatar
dougal dougal is offline
Send a message via ICQ to dougal Send a message via Yahoo to dougal
Re: hmmm
It means that you could add a custom button on your controller, and have it control something extra on your car. For example, you could do a headlight mod on your car, then use the extra channel on the controller to switch them on and off remotely.
ZZ PT Cruiser
Precious "BitChar-A" Honda Accord
MicroSizers Honda S2000
Old 02-20-2003, 11:30 AM
xatu's Avatar
That would be awesome if you wanted to make a little car with a weapon on it, and start Battlebits!
Old 02-20-2003, 04:17 PM
Squishy's Avatar
Squishy Squishy is offline
Quack
wild char-g have wepons on em.
Old 02-23-2003, 12:44 AM
Risingsunn Risingsunn is offline
The question is...IS there an extra channel on the transmitter to use on it?
Old 02-23-2003, 03:32 AM
Im a cat, miow.
The answer is yes- look at the link.
Post it!
Old 02-23-2003, 05:15 PM
O SWEET !
i have tons of ideas for this,the only problem is, is that i dont have a booster, just plain bits ! Where is the cheapest place to get them ?
Old 02-23-2003, 07:23 PM
xatu's Avatar
Hmm... I was thinking, and is there a possible way to ADD a booster thing to your controller? It seems like it is possible, but very hard and complicated.
Old 02-23-2003, 09:21 PM
tiberius tiberius is offline
Known Prick
Adding it to the controller is easy if the controller chip is an TX2C. The RX needs to have a pin grounded. No one that I'm aware of has been able to determine where it is located on the RX PCB of if that pin is actually bonded to the PCB. The actual IC under the blob is just under 1.5mm square.
Old 02-24-2003, 03:21 AM
Im a cat, miow.
I think the only way to remove the blob will be using chemicals, without destroying the chip.
Don't even attemp to use a stanely knife or stupidly- a dremel.
Looks like some google-ing is necessary.
Soldering to that little chip will be a job!
Post it!
extra buttons on controller balbacratz Bit Char-G / MicroSizers 3 11-02-2004 08:08 PM
Extra Bodies e9d6w7a9r2d XMODS Parts and Hop-Ups 2 01-23-2004 12:47 AM
extra cell skeptics....READ READ!!!! lemans23 XMODS Mods and Projects 24 12-30-2003 01:09 PM
Boosters are great rug runners! Zephyranthes Bit Char-G / MicroSizers 0 04-06-2003 05:35 PM
POST Extra parts for trading Deadite Bit Char-G / MicroSizers 7 10-05-2002 03:14 AM
