Old 02-16-2003, 07:50 PM
Zephyranthes's Avatar
Blitzer Sonic
My ZZ has crap range
I gota black civic today. It has crap range. Are there any cripplers on it? The range is only 6 feet, and the antenna is securely attached.
Old 02-18-2003, 08:26 AM
Blamminator
If it is 27 Mhz you will want to do an antenna mod. Radio shack has longer antennas for cordless phone that you can buy. It isn't a very hard mod & it will help with your range. I doubled mine after doing it. You can also get Cad 5 wire & replace the antenna on your car. I did this with a 57 mhz lxx the other day & got great results.
Hope this helps
Old 02-18-2003, 12:12 PM
rawdog805 rawdog805 is offline
Do you happen to have the part number for that antennae at radio shack??? and how much did it cost you???
Old 02-18-2003, 01:01 PM
Blamminator
I am sorry I don't have the number I think it was this one but i am not positive. I took my antenna out of my controller & brought it with me, made sure it was about the same width & was at least twice as long. I had to cut the circle at the bottom of the antenna alittle with my dremel so it would fit in where my original did & BLAM!!! better reception.
I hope this helps.
Old 02-22-2003, 02:58 PM
Blitzer Sonic
Are there any cripple caps on the controller or car? I have a LOT of cat 5 antenna. Black too. It's weird having 6 feet of range when my MS has about 50.
Old 02-22-2003, 09:35 PM
hos hos is offline
I used 270-1405A. Trimmed a little plastic and it was fine. $3.90.
smart range question rydzjunior XMODS Mods and Projects 0 03-03-2007 07:39 PM
Poor range kennylxix XMODS 7 12-22-2004 02:13 PM
Question about range 05WillysJeep ZipZaps Monster Truck 2 12-11-2004 04:43 PM
Sorted crap range pnplf Bit Char-G Mods and Projects 2 09-20-2002 11:30 PM
Judder and crap range pnplf Bit Char-G Mods and Projects 1 09-20-2002 08:07 AM
