Old 02-12-2003, 09:20 AM
Habbi Habbi is offline
Location: Furthest place from the bright center of the Universe
Unhappy Dual Cell Booster
I put a second stock cell in my Tomy Fairlady Z, wired in series. It has a 2.6 motor in it. The problem is I see no speed change in normal speed, but when I hit the burst button the car is definitely faster than it was with one cell. Any one else see this? Is the boost PCB holding back the power to the motor?
* MS Skyline (Cat-5 Ant., Dual Cell, Bulb Headlights, Tomy 2.6) * MS Impreza * Tomy Fairlady Z Turbo (Tomy 2.6, Dual Cell) * H1 Hummer *
Old 02-12-2003, 10:07 AM
kwikbb's Avatar
kwikbb kwikbb is offline
smoove operator
Re: Dual Cell Booster
How did you wire the batteries, in series or parallel? And how are you charging it?
Old 02-12-2003, 11:32 AM
Wired in series. I'm using the stock charger and just hitting it twice.
Old 02-12-2003, 02:32 PM
neoGTR22
I think the problem may be that ur not using the proper charger. From what I understand (I could be wrong, so someone correct me if I am) you need to charge at the same voltage that ur using. So... since u wired them in series ur doubling the voltage 1.4v x 2 = 2.4. So u'll probably need at least 3-4 AA's to charge it.
Old 02-13-2003, 10:33 PM
bdebde's Avatar
bdebde bdebde is offline
That's all folks
Yep, you need to charge at higher voltage. I have a two cell Zip Zap with a booster PCB in it. It goes like normal 1 cell boost speed without the boost, then hit the boost and it flies!
That's all folks!
Old 02-14-2003, 01:35 AM
chelboed's Avatar
chelboed chelboed is offline
Epoch's R Bett'R
Yeah, I usually use 4 AA's for a 2-cell car, and 6 AA's for a 3 cell car.
Strange Observation, zip zap red motor in a 1 cell bit booster, and in a tricell. Clint Bit Char-G / MicroSizers 3 03-20-2003 12:58 PM
Selling/trading it all ( booster , dual cell, parts etc) Suntzu28 For Sale/Trade 4 02-27-2003 12:00 PM
Laymans dual cell vs. traditional dual cell Zephyranthes Bit Char-G Mods and Projects 6 02-18-2003 06:12 PM
