Old 02-11-2003, 10:12 PM
Zephyranthes's Avatar
Blitzer Sonic
Make a 2.2 run like a 2.6
Want to make your completely stock MS run like a 2.6 even though it comes with a 2.2? Just change the pinion gear into the K.I.T. Racer 7 tooth one. I did the math and the 2.2 is just 33 rpms lower than a 2.6. That's like nothing. It's easy and doesn't cost as much as buying a 10 dollar 2.6.
Old 02-12-2003, 03:50 AM
Demon666's Avatar
Demon666 Demon666 is offline
V-tec aholic
I tried this with a seven tooth gear from a clone i have and it has alot of tork but the top end is slow.
Old 02-12-2003, 06:16 AM
strider_mt2k
I tried this on my shen.
I'm currently running the ZZ NOS motor 2.35 and the MS 8.25:1 gearset, and the 7 tooth pinion seem to get a tiny bit more speed out of it.
I was very suprised when I was just able to pop the motor in and run with no adjustments!
This doesn't work at all on my Cyclona though.
Old 02-12-2003, 09:19 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
10$ tomy motor? haha i can get cyclona motors for ten bucks and it comes with a whole car even!!
the cyclona motors are better
if I could make you ANYTHING out of plastic.. ?? Draconious XMODS Parts and Hop-Ups 22 04-07-2004 05:31 PM
2.2 vs. 2.6 vs. 3.8 Namuna Bit Char-G / MicroSizers 14 08-23-2002 09:30 AM
2.6 motor and 2.2 carver Bit Char-G / MicroSizers 15 08-04-2002 05:06 PM
