Old 02-11-2003, 08:56 PM
Vyrus Vyrus is offline
L&M Autoworks
Send a message via AIM to Vyrus
Horrible range?...
Hey guys I got my Char-G SE Skyline in the mail today, and put in an R-Spec engine. Everything works fine and the top-end power is amazing (but I will be buying gears soon because I don't like the low-end lag ). Pic linked in the sig.
Anyways I notived the range on this thing is horrible. I mean 5-10ft if I'm lucky. Is this normal? My friend has a 350Z and he put a longer, slightly larger antenna on it, and we measure a 40ft range on it. I opened up my controller and couldn't find any capacitator. Do most Char-Gs have this horrible range stock? And with the antenna I will get great range?
Thanks for any help,
-Cyrus
ZIPZAP 1969 Baby Blue Camaro Yenko.. ToyEast 3.8 motor, Tomy 8.25:1 gearing, ToyEast 150mAh NiMH, Tomy SE fullsize wheels, Tomy front knuckles, Tomy soft swaybar, Tomy tires (pink front/blue rear).
Also: Tomy GS-03, Tomy GS-04, Tomy GS-07, Tomy 2.4 motor, TinyRC.com R-Spec motor, ZZ 2.15 motor, Guards Red Porsche 911 body, 2003 Ruby 350Z body, 1970 Orange Dodge Challenger Challenger body.
Old 02-12-2003, 05:11 AM
L&M Autoworks
Anyone?
Old 02-12-2003, 09:34 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
my guess is that its a 27 35mhz/ lower frequencies dont travel through the air as easily. ive owned about 4 27mhz cars and all of them got 5-10 feet. this is about the 40th post that ive told people to wire a 3rd battery into the controller circuit(series). this will double the range. a longer transmitter antenna helps as well.
or you can go and try to rip things off of circuit boards and hope you dont mess up. or maybe adding "cat-5" wire will ad about 6inches of range.
Old 02-12-2003, 03:28 PM
L&M Autoworks
Good to know. I'll also consider adding a 3rd battery to the controller, are there any write-ups on this? Today my friend is installing the thicker antenna, and when it gets home I'm dropping in a 150mAh battery as well.
-Cyrus
Old 02-12-2003, 04:18 PM
hogjowlz's Avatar
they wont give you much range increase.
i dont think theres any real documentation on adding a 3rd battery but i used to have a zipzap controller with one and it really helped.
Old 02-12-2003, 11:20 PM
grilleguard2k grilleguard2k is offline
Send a message via AIM to grilleguard2k
Look, Cat-5 is basically the same stuff your stock antenna is made of. What you really want to do is rig up a Mini-Z style antenna, solid core wire without insulation. Not only will this give you a cool Mini-Z look, but it will also increase your range by a significant amount. Cat-5 is mainly for letting you choose what color you want your antenna to be. Real range is in the 24 and 22 guage wire. Copper is highly recommended.
Would YOU hit it?
smart range question rydzjunior XMODS Mods and Projects 0 03-03-2007 07:39 PM
ZZMT Remote Range 88-Fiero-GT ZipZaps Mods and Projects 1 10-09-2005 09:03 PM
Question about range 05WillysJeep ZipZaps Monster Truck 2 12-11-2004 04:43 PM
HELP! Horrible range with 27 Mhz Telstar ZipZaps 3 11-12-2002 08:28 PM
range of 27 MHz versus 49 MHz gRC ZipZaps 12 09-30-2002 06:33 PM
