02-10-2003, 08:12 PM
Epoch's R Bett'R
Run 2 Frequencies on 1 std. controller!
Okay, I have a 27, 49, and 57mhz cars. I am tired of hauling around so many controllers, and I don't wanna buy a multi (which doesn't accomodate all of these frequencies anyway.
Here's my solution... Run as many frequency crystals on 1 contoller as you want with a switch to select between them. You could run all of the frezuencies out there if you get the right switches.
02-10-2003, 08:16 PM
man dude thats one of the best mods ive ever seen thats dope dude
02-10-2003, 08:35 PM
isk8element too.
dude sweet
dude thats sweet but what would be cooler id witha bit char-g booster car is to do that mod on it except with all four freq. and then buy the booster machine sets and you can use wich one when you want
02-10-2003, 08:48 PM
Epoch's R Bett'R
Yeah, but I don't have enough room right now in my booster controller because I installed my alternate booster button mod on it. Check it out in the mods forum. I agree, though. It's totally possible and if you got a multi controller, and added the american frequencies, then you'd have everything plus the booster fctn.
ed
02-11-2003, 05:10 PM
Quack
that is awsome man!
02-12-2003, 08:19 PM
Great mod!
Two thumbs up, way up!
02-13-2003, 08:07 PM
With the proper rotary switch and the right crystals, you could do all available frequencies!
(I don't know how small it would be though)
Again, really great mod.
02-13-2003, 11:43 PM
Bad Driver
You should just use two crystal sockets, one for the car and one on the controller.
03-10-2003, 07:43 PM
Can you use two freq's at once by soldering the crystals in parallel? I know it would only limit the number of people I could race. I broke my controller, but I have the crystal.
03-11-2003, 07:48 AM
Chief Propeller Head
Excellent mod chelboed!
Just wanna clear up a few things though.
BillyP: you can't solder them in parallel, it just won't work. I think the low freq crystal will cancel out the higher freq one.
Nathan: the car isn't crystal controlled, but based on what is called a tuned circuit. This is determined buy R, L & C values in teh receiver stage of the circuit.
In fact I'm trying to design a new receiver circuit that can have multiple freq's.
Check it out
here at ausmicro.com
ph2t.
03-12-2003, 03:16 AM
Is it possible to get those crystals somewhere? Rather than to just pull them from another controller?
It would be great to not have to buy whole controllers just to have other frequencies!
Also, I had a question, perhaps one could install a switch to reverse the forward/backward controll so that you could drive both zips and bits with them?
any input on that would be great!
03-13-2003, 02:03 AM
Tool User
Your LHS should have the crystals.
And it would probably be possible to wire in a switch that inverts your forward and backward control. If I wasn't tired I'd start trying to figure it out now
03-13-2003, 12:55 PM
local hardware store?
03-13-2003, 01:55 PM
BIT PIMP
LHS = Local Hobby Shop
silla
03-13-2003, 02:17 PM
You can get all the electronic stuff you'll ever need (almost) at this site, hence the name, All Electronics.
