08-30-2002, 01:13 PM
www.d1gp.com
adding suspension springs...question
hi, im new to the bit charg and i have yet to fully disassemble it.....last night i had an idea to....well... break my cheap mechanical pencil and take the spring that is used to load lead...
the spring is a good diameter and i cut them to the right size, and i KNOW they are going to fit....but the problem is...i cant seem to figure out how to open the hatch under where the struts are without breaking anything ;/
if someone has a diagram or a solution..please tell me
thanks in advance
08-30-2002, 02:10 PM
BIT PIMP
I have done this to all my cars. The tricky part is cutting them to the same length, so the car is balanced. Once you take out the screw under the clear PCB cover, disassemble the front end and get to work. Always test the steering before you fully re-assemble the car, in case you need to make adjustments.
Good luck.... the link provided by billybonz has great pix
08-30-2002, 02:15 PM
BIT PIMP
Here's another pic. with the body...
08-30-2002, 08:00 PM
payaso, what type of pen/pencil did you use? It seems like you have to get just the right one or it will be too stiff.
08-30-2002, 08:08 PM
Shoot To ILL
that mod works really really well in my Trueno, it actually changes the handeling and works really well on rough surfaces
Custom:
Toyota Trueno
tires: soft
gear: light blue
shocks: mediums
motor: 2.2
08-30-2002, 10:09 PM
BIT PIMP
These springs are gold plated, and from QFM. BIG PIMPIN..
My supra has the silver plated bling bling.. Gotta love QFM.
silla
09-07-2002, 11:34 PM
sLaNteD ViSiOnS
hey...how do u guys get the steering to work after u put the springs in....?
i put perfectly fittin springs in yesterday....but the steering was bad cuz of the magnet gettin attracted to it......
how do u guys prevent the magnet from gettin attracted to the spring...?
"Nobody is perfect until you fall in love with them."
- Me
OH YEAH, GO KILL A BIRD!
09-08-2002, 01:19 AM
BIT PIMP
That's impossible. If anything, it would help draw the magnet over, cause the springs are located on the sides of the car. What happened is that your springs are too stiff. The coils don't have enough power to pull the magnet if the springs are putting too much pressure on the suspention. Try cutting them shorter and see if that helps...
silla
09-08-2002, 02:30 AM
In the QFM website, It said that those springs were 'Tomy micro springs'.. but what are they orginally for?
thanks
shoot to kill
09-08-2002, 08:56 PM
sLaNteD ViSiOnS
my springs r not too stiff....
they r shorter than the shaft cuz im tryin to lower the chassis but still have good steering....
i dunno wats wrong wit it but until sum1 can help me im running it normal....
- Me
09-08-2002, 11:24 PM
www.d1gp.com
i change my mind
heh yeah....i took out my springs...i think it was a bad idea now...cuz at first they were too bouncy...and my steering was off...so i took em out...
i think im going to somehow find/make plastic springs  or some other contraption
09-10-2002, 02:22 AM
Moderator - Modifier
Bay on Aim and MTL,
I dont recommend using pen springs because we have tried that before and the tension is too stiff, and the springs are magnetically attracted which throw off steering. I believe that is what is causing your problem. We sell non-magnetic springs that are delicate enough to compress on the Bits own weight. Unfortunately we are out of stock at the moment though. Also, this isnt the easiest mod to do, so I dont recommend trying it until you are comfortable disassembling and reassembling your front end.
QFM Racing
http://questformadness.com
09-10-2002, 04:19 PM
sLaNteD ViSiOnS
u act as if im a newb.....
lol............
- Me
09-10-2002, 07:12 PM
www.d1gp.com
dun worry bout the springs anymore...heh i took off my strut bar a few days ago...trying to see the difference in performance
seems the same, but with a more low profile look
