Old 02-04-2003, 11:37 PM
Zephyranthes's Avatar
Blitzer Sonic
Instant range increase.
For people who don't wanna mess with the soldering to take out the cripplers or make a whole new antenna this is the mod for you. All you do is lift your pcb board and untie the not in your antenna. Turn the antenna around and make it stick out the back of your pcb board instead of the front. It's a whole lot easier than drilling a hole in the front of your body, it gives you a longer antenna then the drilling hole in body mod, and it looks a whole lot better than drilling a hole in yor body. If you really want the maximum output of this mod, unsolder the antenna and solder it back on so it sticks out backwards.
Old 02-05-2003, 05:32 PM
Vyrus Vyrus is offline
L&M Autoworks
Send a message via AIM to Vyrus
I did this yesterday to my clone, honestly I don't think it makes any range increase. Actually, I don't think it's a good idea since it makes the antenna much easier to rip out.
-Cyrus
ZIPZAP 1969 Baby Blue Camaro Yenko.. ToyEast 3.8 motor, Tomy 8.25:1 gearing, ToyEast 150mAh NiMH, Tomy SE fullsize wheels, Tomy front knuckles, Tomy soft swaybar, Tomy tires (pink front/blue rear).
Also: Tomy GS-03, Tomy GS-04, Tomy GS-07, Tomy 2.4 motor, TinyRC.com R-Spec motor, ZZ 2.15 motor, Guards Red Porsche 911 body, 2003 Ruby 350Z body, 1970 Orange Dodge Challenger Challenger body.
Old 02-06-2003, 12:39 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
old news, but ive put a new phat antenna from my speakers on a long time ago...and its like 7 inches .... doesnt drag on the floor, so its all good
Old 02-07-2003, 06:27 PM
Heat's Avatar
Heat Heat is offline
Zhuge Liang - My Idol
that knot wasnt put there to reduce your range, that knot was put there so that when you pull on the antenna, you don't rip it out. people like to just grab the antenna to bring their car up so they put the knot there. but i dont do that so i untied it but for those of you that do, it's probably better to leave it there. also regarding the little brown thing inside your car's chip, I removed mine with much effort yesterday and it has really increased the range. On half a charge, I got about 5 feet of range WITHOUT pulling the antenna out at all.
Old 02-08-2003, 11:16 AM
Silent_NightR34's Avatar
Got Mini-z?
i thought i had more range when i did that...i thought i posted a thread about it once.o well..i always forget were and what i posted on
Old 02-09-2003, 11:04 PM
timis2's Avatar
timis2 timis2 is offline
I do that with all my cars
Old 02-11-2003, 10:34 PM
cowfish_29's Avatar
yellow fish forever!
i don't like it b/c the antenna is just flopping all over the place and getting in the way, along with looking just "ridiculously long"
Depending on if you are lucky, a cat5 antenna might help (this makes your car tip over more often though) or extra power from your transmitter might help too.
Old 02-12-2003, 10:01 AM
Blitzer Sonic
My car uses a Cat5 antenna. It doesn't tip over either. Total range of 25 feet. You can always remake the knot in a lower area so you won't pull the antenna out.
Old 02-15-2003, 06:41 AM
strider_mt2k
It's very simple!
Do the cat5 thing, or simply run it out the back of the PCB, but loop it up and through the little clip on top! That way you get what's called a "strain relief". No performance loss either!
Here's an example.
Mods to increase range? SoulSpear ZipZaps 3 12-21-2003 01:34 PM
how to increase range? DeeCee2 XMODS Mods and Projects 0 12-08-2003 10:57 PM
Range Increase Lestertech ZipZaps 1 07-21-2003 12:50 PM
Best way to increase zip zaps range BitZipAddict ZipZaps 21 05-29-2003 04:37 PM
Booster Controller range increase e_lm_70 Bit Char-G Mods and Projects 2 10-14-2002 10:35 AM
