02-03-2003, 08:03 PM
What Can I Do
WHATS UP
I have a gold civic and a bit char-g silver supra with a 3.8 motor, nos, tubro, green gears and stock gears for the supra i would like to know what can i do to them to make them run faster and look better.
thanks
1 gold civic zap zip
02-03-2003, 08:12 PM
Bit Baron!
Welcome aboard!!! as for your question, i really couldn't tell ya, seems yours are better than mine so...
Black Honda Civic Coupe Zip Zap
-Sport Tires
-Turbo Gears
-Green Motor
-Chrome Rims
02-03-2003, 08:17 PM
Corolla Power!
Welcome to the forums!
Before asking here you should search the site a little bit...try the big 'Tips and Mods' up there ^. It should help you quite a bit. Also check out www.questformadness.com
02-03-2003, 08:35 PM
i have looked around and can't find nothing and i just want to know what i can do.
02-03-2003, 09:50 PM
Told ya.
You can add bats to the cars, search for dual cell and triple cell mods. The addition of extra bats should make your cars fast enough.
____________________
Meh.
02-03-2003, 10:11 PM
Take the PCB out of the BIT and put in in the Zip...Scrap the Zip PCB...Buy two 150 Mah 1.2 Volt batts and duel cell it...Then buy a Fast and Furiuos body and put on it..
Or better yet, go to Wal-mart and buy a $14.00 Motorworks and use its PCB, faster than the bit PCB and smaller...
Will be very fast, more controlable at high speeds and look cool...
you can find all the help you need just by surfing the threads, there are thousands to choose from...
thats the fun of it.....
Speed is just an equation of time and money.....
02-04-2003, 07:07 PM
ok thank. Are these mod hard to do and i can't find the fast and furious kit any where.
02-04-2003, 07:24 PM
GaN: Blue
You can probably use the R-Spec motor. It isn't as fast as a 3.8 but can give you much better acceleration.
http://tinyrc.com/shop/product.php?pid=413
< Plane construction paused>
Current Progress: 0%
02-05-2003, 08:28 AM
The PCB switch is not too bad, just takes some time to change over the wiring. Have to solder eight wires and then set up the batteries. I've done three so far and about to start a three cell mod with a Motorworks PCB...I suggest you just take your time and write down where all the wires go....also make sure to label the steering wires or change them over one at a time...
Just go out on the RS web site and do a location search for your area and themn just start calling about the bodies, eventually you will fing a store that has them....
Just take your time, my first one took about 3 hours...
