02-03-2003, 05:06 PM
Quack
Charger idea
Hey, has anyone tried to use like a head phone jack to charge with? like it would plug into the side of the car (like a gas pump) and charge the bit? also, you could have it ravel up like the MS anteannas. heres a pic, cause my explaining stinks.
02-03-2003, 05:07 PM
Quack
opps sorry, here it is
02-04-2003, 02:28 AM
Tool User
It could be done, but it would add more weight to the car.
This would be almost ideal if you were building a monster-bit where you couldn't get the bottom of the car near the charging pad.
You could take a clone and drill out the screw-hole in the bottom to accept a 1/8th inch phono-jack, then you just have to make some contacts, and wire it to your battery clips. The down-side is that you wouldn't be able to do an 'Internal Two Battery' on it unless you do the Layman's dual batt.
Or You could do about the same thing with it over the heatsink, and drill out a giant 'gas filler' in your body. But you'd probably have clearance issues with a body.
02-04-2003, 04:20 PM
Quack
thanks, i was wondering if clearance would be a problem. For my ricer car i might do this just for the "gas pump" effect when charging
02-05-2003, 10:07 PM
Perfected Bit Modder
will asairrr( as soon as i rob the rat shack)
i hate radio shack....
02-07-2003, 05:00 PM
Quack
anyone else have anyhting to add? please?
02-08-2003, 01:14 AM
aight, i'm gonna use a 3/32 mono jack which will plug on the leads of my charger http://tinyrc.com/forums/showthread....&threadid=8047
i'll have to get the parts from the rat shack...
02-08-2003, 11:53 AM
My Alter Ego Is Retarded
Thats how Epoch indoor racers charge.
I like Pie
02-08-2003, 05:52 PM
Quack
hmm... i think i may just rip up a epoch and use its innards...lol
