Old 08-28-2002, 07:58 PM
Arrive2Defy
Question Booster!
Ok I'm not an idiot... I'm just slow. Anyways, I know I've heard about the booster thing for a while and still don't get it. Please someone explain it to me like I'm a 5 year old. If you have pics even better. Is it JUST the controller (the 4 ch one)? Or is it something that you actually have to put INTO your car? Help me out someone... thanks!
Old 08-28-2002, 10:51 PM
Token User Token User is offline
Someone correct me if I'm wrong (I know someone will), but a "Booster" is a car with a slightly different circuit board. The extra circuitry allows it to have a "special feature" activated via the 4ch remote - in this case, the feature is that it RESTRICTS the current going to the motor, allowing the motor to run at lower RPM, slow the BCG down, and make it more manouverable through corners.
OK, most people have taken the original intent and flipped it. They drop say a 3.6 motor in, and run it at the "slow" speed by default, then activate the "boost" and run at full voltage, giving the "turbo boost" effect in a straight line.
End result it more fun
Old 08-28-2002, 11:12 PM
Arrive2Defy
Angry DOH
so you have to buy a car with "boost" ALREADY IN IT? DAMNIT! aw... screw boost... imma try to figure out how to do a duel battery mod... WAHAHA! >=D thanks anyways...
Old 08-29-2002, 04:24 PM
skylinebeyond skylinebeyond is offline
Okay. you buy a bit char-g.
Normal, stock. it doesnt need to have boost.
Then you buy a 4ch controller. The white greyyish purple ones.
Then you buy a booster machine set.
This set includes a 2.2 motor.
Install the machine and engine in your car, turn on your controller and your done.
Thats all there is too it. Buy it off toyeast if you want. Thier set includes everyhting you need for 38 bucks. booster machine 2.2 3.0 and a controller. Everything you need.
Old 08-29-2002, 08:55 PM
kbtoyz902's Avatar
kbtoyz902 kbtoyz902 is offline
Bit OG
Send a message via AIM to kbtoyz902
u just need your boost machine, and 4 channel controller. I ftahts what skyline was trying to say, my bad, it sounded like you sed buy a bit, and a boost.
Old 09-23-2002, 08:45 PM
JaMeZzZ122 JaMeZzZ122 is offline
Send a message via AIM to JaMeZzZ122
is it possible to do this with a 3.8 motor...if so im up for this cuz it would be pretty phat...opinions on this would be nice
Old 09-24-2002, 06:41 AM
Arrive2Defy
wahoo got a boster set and a 3.8.... smokin~
Old 09-24-2002, 02:46 PM
im goin to get teh booster now because of the info but i have to ask what is meant by going at a slow speed then using the boost...i cant go the fastest it can go and use boost?
Old 09-24-2002, 04:35 PM
Arrive2Defy
the booster set has 3 options..
1.) Slow as hell
2.) slow but you have option of turbo (boost to max speed)
3.) supercharger (boost is on all the time)
if you wanna go fast then just put to option three.. i like to have some fun with my bit so i put it to 2...
Old 09-24-2002, 05:54 PM
this is the booster that i saw on some site and it looks like a whole new circuit board...can someone explaint he things u put into the actual bit
Old 09-24-2002, 09:39 PM
Arrive2Defy
the booster and the reg bit is about the same just that the circuit board is made diffrently so it can handle two speed. im not sure what they did differently...
"things they put into their actual bit"
read below...
Old 10-04-2002, 12:24 PM
actofgod actofgod is offline
Bit Surgeon
how much change in voltage?
Ok, I understand how the booster kit works now. Can someone who has one tell me how much slower it goes at the slow speed?
As in a 3.0 motor in slow-mode drop to.. what speed? About like a 2.2? 1.6? Perhaps you could do a little research and make a table showing all engines and their approximate RPM at the slower speed. I'd appreciate the help!
Old 10-04-2002, 11:38 PM
Arrive2Defy
compairing speeds...
on i hvae a booster and here is what i have learned...
on regular speed (non boost) the sh!t is slow as hell! i have a 3.8 motor and it runs like a..uh.. i donno but really slow... 2.2?
on booster mode itll rip! the thing is crazy fast.. faster then regular 3.8 motor...
so in conclusion.. always keep it on for speed, but take it off for turns so you wont flip.. =P
Old 10-15-2002, 05:35 PM
Arrive2Defy
the BOOSTER controler (4 channel) has a button... on the upper right hand side (corner). if you ever played playstation or Super nintendo. it is where the R(R1) button is. All you do is hit that to go to booster mode ten release to go back to normal mode.
Setting A - ALWAYS on regular mode
Setting B - Booster option is open
Setting C - Booster is ALWAYS on
have fun... ps if your thinking about buying a booster set or not... buy it, its more fun also faster then stock.
Old 10-16-2002, 08:06 PM
323iT's Avatar
323iT 323iT is offline
Send a message via AIM to 323iT
since everyone who read this are/will be booster users,
here's a lil tip you probably don't know.
the newer booster machines. (from auto modelista and possibly the 350Z) have faster regular speed and boost speed. i ran my old booster machine and the one from automodelisa and the auto modelista is almost twice as fast in regular and boost mode. so if you're interested in getting more booster machines, i'd get the 350Z or auto modelista
can these 6 frequencies run together? 2 bits, 1 MS and 3 booster clones? eman1 Bit Char-G / MicroSizers 8 08-06-2003 08:20 PM
Strange Observation, zip zap red motor in a 1 cell bit booster, and in a tricell. Clint Bit Char-G / MicroSizers 3 03-20-2003 12:58 PM
Booster & 4-Band Experience Blue Bit Bit Char-G / MicroSizers 19 02-18-2003 08:04 AM
Alternate Booster Button! chelboed Bit Char-G Mods and Projects 7 02-11-2003 07:57 PM
