Old 02-01-2003, 11:34 AM
t-squared's Avatar
t-squared t-squared is offline
Bit Obessed...
Arg!!!!
Has this happened to anyone? I'm trying to make a ecilpse spyder, and............ARG! This is like the fourth time, first it was just a crack in the window, and it gets worse and worse!!!!!!
I tried epoxy putty and superglue.......what else should I use? is JB weld worth it? cause it like $7.99 CND...........
Old 02-01-2003, 03:43 PM
biohazard's Avatar
biohazard biohazard is offline
quick fix
Well I have done this to one of my custom cars. I tried glue/epoxy, which does not work. I fixed this problem by melting new plastic to the break. It is very tricky because the heat will shrink the body. I used a soldering iron to fuse the plastic. I hoped this helped you out. If you have any questions let me know.
batteries Awaken Bit Char-G / MicroSizers 1 05-13-2003 08:12 PM
Arg.... I think I destroyed my bit... retroicon Bit Char-G Mods and Projects 15 09-15-2002 09:45 PM
