Old 01-30-2003, 02:27 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
reduced turning radius
ok for those of you with dual battery cars you know how easily they flip over in a turn right?
well the rare earth magnets come two in a pack. these two are the same size as one stock magnet. i just tried using 3 halves of the rare earth. this leaves less space between the magnet and the electromagnet. i havnt glued it into place yet but this seems to help flippage a little. for those of you who like to do donuts over and over this isnt for you.
Old 01-30-2003, 02:56 PM
Rusty Brown's Avatar
Rusty Brown Rusty Brown is offline
I Love Bitches
I heard somewhere if you put some hard tires on the front, it won't flip cos of the lack of grip.
Old 01-30-2003, 03:01 PM
hogjowlz's Avatar
they lied. i flip on thick carpet.
Old 01-30-2003, 03:02 PM
ZeroTT ZeroTT is offline
Hard tires on the front will generally keep the car from turning over, but it does it by creating understeer from the lack of grip, so while it doesn't flip, it doesn't really turn either.... I can still flip mine with hard tires though...
(WRC body)
"It is not the spoon that you wish to bend, but rather, the will of the spoon..."
Old 01-30-2003, 03:48 PM
hogjowlz's Avatar
ok my limited testing on this has yielded promising results.
the good: it definatly keeps it from flipping as much. in combo with suspension springs it will accelerate while in a turn without doing donuts. i think it is possible to "drift" now. im still not 100% sure what constitutes drifting but i imagine you could turn while spinning the rear tires at slower speeds. its cool watching one side sag while its turning.
the bad: you cant turn as tight. you have to center it exactly. you have to glue it in there. you will pick up bigger pieces of metal. its still possible to flip(not as likely).
Old 01-30-2003, 09:49 PM
Dorifto! Dorifto! is offline
Drift!
wouldnt replacing the front wheels with the plastic front wheels from a hotwheels kit racer acheive the same result? This to me seems like a better way to acheive the same result without adding the extra magnet in the front to pick up more metal.
All your base are belong to us!
Old 01-30-2003, 10:05 PM
dieselboy dieselboy is offline
Send a message via AIM to dieselboy
not sure if you are talking about solid plastic no rubber wheels becuase i haven't seen a kit racer. If so though, adding thoes to the front would create no grip on surfaces such a hardwood. It would be the same as taking the tiers on the front wheels and just running on the plastic rims.
Turning Radius? hschnark ZipZaps SE 3 04-19-2006 07:05 PM
turning radius rob3662 SuperSlicks 0 12-08-2004 05:54 PM
Unequal Right and Left Turning Radius Fix backtrack9 XMODS Mods and Projects 20 10-02-2004 02:32 AM
turning radius? VuN86 XMODS 0 10-27-2003 11:31 PM
Uber Help Needed w/ Turning Radius. ZipRC ZipZaps SE 5 10-01-2003 08:26 PM
