Old 01-30-2003, 05:41 AM
-v2oracle-
reception problems
im having problems with my LXX Xanavi, the onyl lil' prob is the reception in this lil' baby is awful, i've looked for the crippling capacitor in the remote and its not there......it only has a few feet, and then the car tends to have jerky responses to turning, and when forward/reverse is pressed with turning it gets really jerky, this also happens more as the battery dies off...........does anyone know why this is happening and how i can fix it? is it just a bad attenna? any help is greatly appreciated
Old 01-30-2003, 07:41 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
its probably a 27mhz. more batteries in the controller and a bigger antenna.
Old 01-30-2003, 08:46 AM
kwikbb's Avatar
kwikbb kwikbb is offline
smoove operator
It's quite possible that there is a 'Crip Cap' on the PCB in the car too. I myself am only familiar w/ Tomy products... maybe someone with a little more experience w/ LXX can chime in and shed a little light on this. I mean if there is a difference at all in the construction and schematics of the PCB's.
Old 01-30-2003, 09:09 AM
hogjowlz's Avatar
i wouldnt try to remove those little smt(surface mount technology) caps. that stuff is small and you really risk wrecking your board. ive read many times on this board where people totally ruin a good car by doing a mod that is not totally necessary.
it is a lot less invasive to wire a 3rd battery into the controller and to ad a larger antenna on the controller.
Old 01-30-2003, 03:12 PM
-v2oracle-
thanks, the PCB layouts are identical to that of TOMy's (which is great for mods, helps me out laods so i can practice on cheaper cars) so i think i'll see if a third battery helps(so just add another AA in series to the controller?) and kwikbb can you explain what you mean by crip cap (cirppling capacitor), cuz i checked in the controller and there was nothing.........but you were saying there may be one on the cars PCB?
Old 01-30-2003, 03:18 PM
hogjowlz's Avatar
yes in series so theres 4.5v going through the controller. this gives you about 2x the range and it will allow you to charge a dual battery car if you ever want to do that which i highly suggest.
and to answer your question towards kwibb yes if there isnt a cripple cap in the transmitter, there may be one on the pcb. it is really really small and even if you are skilled at solder removal i would suggest not risking destruction of a perfectly good car. if you still want to do it check out www.questformadness.com
they have detailed instructions on what to do.
Old 01-30-2003, 03:28 PM
kwikbb's Avatar
smoove operator
-v2oracle-, the link to www.questformadness.com that hogjowlz gave should sufficiently answer your quesion and guide you if you choose to to dive into it.
And yes hogjowlz is correct, if you aren't comfortable with a soldering iron then pass on this particular mod... it is advanced. But if you choose to do it, good luck and let us know how you make out!
Old 01-30-2003, 04:13 PM
-v2oracle-
alright well i just modded the battery casing and had three AA in there, now my car wont charge on it, so im gonna scrap that ( unless anyone can tell me why its not working) and put it back to two AA, im gonna go looking for that PCB crip cap....
Old 01-30-2003, 04:15 PM
-v2oracle-
alright i can see it........stupid crip cap
im gonna go for it
im pretty handy with a soldering iron, and i have steady hands from making models
so hey
lets see how it goes, i think my only problem may lie in the fact my soldering iron head may be a little oversized.......well here goes nothing
Old 01-30-2003, 05:04 PM
-v2oracle-
well i removed it, but still same problem...........arrgghhhh frustrating, got a soldering iron burn on my hand too cuz of it
Old 01-30-2003, 05:23 PM
hogjowlz's Avatar
im tellin ya
just run a 3rd battery and bigger controller antenna. or get a clone that has better range and transplant the pcb.
Old 01-30-2003, 05:31 PM
-v2oracle-
the thrid battery set up didnt work, it wouldnt charge the car either....its a single cell LXX, and after removing the crip cap, AND trying the third battery, checking the wiring im still getting nothing or no improvement. does anyone know where abouts on the circuit boards is the part that controls the running frequency?
Old 01-30-2003, 05:41 PM
hogjowlz's Avatar
you will need to make a 4 battery charger to charge a multi-battery car.
Old 01-30-2003, 06:39 PM
-v2oracle-
yea i know, i read that in the mods at questformadness, but i think i'm just going to give it a new attenna and double twine it
Old 01-30-2003, 07:25 PM
Dorifto! Dorifto! is offline
Drift!
"I" removed the cripple cap from the board of my GTr set and just about doubled the range of my car. I wonder why it didnt work on yours?
All your base are belong to us!
Have you had problems with your 2.8 or 3.4 motors? NatakuARN ZipZaps 3 05-23-2003 05:26 PM
Steering problems because of pcb Zephyranthes ZipZaps 16 05-03-2003 12:06 PM
Problems with R-Specs... Vyrus bitchar-gmotors Customer Support 6 02-27-2003 02:02 PM
4-band controller + reception Duo64 Bit Char-G Parts and Hop-Ups 18 02-10-2003 01:47 AM
Steering problems Go0ty ZipZaps 1 10-08-2002 07:20 PM
