Old 01-26-2003, 08:37 PM
ronak26 ronak26 is offline
Send a message via ICQ to ronak26 Send a message via AIM to ronak26 Send a message via Yahoo to ronak26
using controller and pcb from i-racer in bit please help (expirenced users only))
will this work? cuz i dont wanna pay 20 for the digi q stock controller, and the bcg 100 pcb when i can pay 20 for the i racer but will i get the same results of proportional speed
if that makes no sence i just wanna know if i can do this mod on this site http://www.tapspring.com/BCQ.htm using a iracer controller and pcb instead of the digi q controllor and the 20 doller pcb alright later
Old 01-26-2003, 09:48 PM
shocon2k
You cannot get proportional steering in a bit. This is because bits use an on-off system with magnets instead of steering servos with feedback. However, you may be able to get proportional speed from your motor.
Old 01-27-2003, 02:03 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
The direct answer to your question ronak is yes, you can do it.
The problems you face (since it's an iRacer pcb, not the tapspring one)
- You'll have to figure out where to solder the wires (it's not necessarily the same as the tapspring)
- You'll be stuck with the ID of whatever the pcb of the iRacer is...The tapspring allows you to set the id to what you want.
If you can figure those things out, you're all set.
Bit Char-Q: IR PCB swap Namuna Bit Char-G / MicroSizers 8 04-15-2003 10:44 PM
Wtt 4 A Drr strakka For Sale/Trade 0 04-09-2003 09:23 PM
Servo PCB as Prop Speed controller! scottyboyfun Bit Char-G / MicroSizers 2 01-03-2003 08:51 AM
My ZipZap now runs circles around my Bit! (dual batt success) caver01 ZipZaps 16 11-05-2002 11:22 AM
