Go Back   TinyRC.com > 1/43 and Smaller > Epoch RC1/43 Indoor Racer > Epoch RC1/43 Parts and Hop-Ups
Old 08-25-2002, 05:02 PM
tinyrc's Avatar
tinyrc tinyrc is offline
New Article: Gertman's 4-cell Mod
Check out this excellent write-up by Gertman of the 4-cell mod for the Epoch:
http://tinyrc.com/articles/epoch4cell/
FYI, we will be stocking assembled packs in the Shop shortly.
Please post any questions that you have about this mod to this thread.
Old 08-28-2002, 05:10 PM
MicroRCracer MicroRCracer is offline
Micro RC Innovator
are the stock batteries on the the spec 2 nicad or nimh?? and what is the difference in the spec1 oand spec2 in battery wise?? do they both have the same batteries??
Old 08-28-2002, 08:11 PM
gertman's Avatar
gertman gertman is offline
As stated in the article, the stock batteries are NiMh. The Spec 1 and 2 use the exact same batteries. The difference is in the Spec1 you have to make room for the 4th cell. It's not a drop in mod. I have been told it can be done but I have not attempted it.
Old 08-29-2002, 04:59 PM
gertman's Avatar
This is the charge adapter I made for my Epoch's:
Old 08-29-2002, 05:08 PM
gertman's Avatar
Here is a close-up of the connector I use on my peak charger. It a uni-sex connector: no male or female. They are also referred to as sermos connectors and red and black connectors. I use them on all my 1:10 scale packs.
Old 08-29-2002, 06:59 PM
Micro RC Innovator
is that plug for a 1/10 th scale peak charger..if so, how many amps do you charge at??
Old 08-29-2002, 09:47 PM
gertman's Avatar
MicroRCracer,
First of all there is no scale when it comes to charging . Yes, the peak charger I use for my Epoch batteries I also use for the batteries in my 10'th scales. I charge the batteries for my 1:10 scale cars at about 5.6 to 6.5 amps. For my Epoch, I charge at 1 amp or less!!! Usually around 0.6 or 0.7 amps.
Old 08-30-2002, 12:22 AM
tinyrc's Avatar
gertman, any idea if the Epoch plug is a standard size so that people can buy a new plug and keep their old charger intact?
Old 08-30-2002, 02:53 AM
gertman's Avatar
No but i'll try to look into it.
Old 08-31-2002, 02:21 AM
Micro RC Innovator
Hello gertman,
what would happen if i added a bitcharg nicad battery(1.2v / 70mah)to be the 4th cell..can you mix nicad and nimh?? what are the pros and cons??
Old 08-31-2002, 02:47 AM
gertman's Avatar
MicroRCracer,
I don't mean to put a damper on your creativity or anything, but the simple answer is NO!!!!!
The absolute rule when adding a cell to an already existing pack:
Try to use one as close to the originals as possible.
What is meant by that is the brand of the cell and mah. Everything else HAS to be match EXACTLY!!! This would be stuff like:
size of the cell-------ex. AAA, sub C, 1/3 AA
type of cell-----------ex. NiCd, NiMH
voltage---------------ex. 1.2, 1.5
So in answer to your last question, NO NO NO, please don't try mixing NiCd cells and NiMh's. They are totally different technologies which are NOT compatible at all!!! They have to be cared for and charged differently.
If this was done, doesn't matter which type was in the majority, the pack would NEVER work properly if it worked at all!!! Meaning, if you did manage to get it charged it would NOT last very long at all and with in 2 or 3 charges the pack would be totally dead if it hadn't yet exploded!!
IF I scared you I mean to!!! Please, please do NOT try this EVER in any situation RC or unrelated.
Old 09-02-2002, 03:18 AM
Micro RC Innovator
HEY GERTMAN!!
I TRIED THE BITCHARG BATTERY ANYWAYS AS THE THIRD CELL FOR MY SPEC 1 SINCE I USED THE THIRD CELL FROM MY SPEC1 TO BE MY FOURTH CELL FOR MY SPEC 2..
I CAN ONLY TELL YOU THIS...THE NICAD CELL THATS MY THIRD CELL ON MY SPEC1 HAS ABOUT 10% MORE PUNCH THAN THE STOCK 3 CELL NIMH..I GUESS YOU CAN SAY THAT IM USING A NICAD CELL + 2 NIMH WHICH IS SUPPOSED TO CLASH OR TO BE A MIX MATCH, BUT IVE BEEN CHARGIN AND PLAYIN LIKE CRAZY AND IT KICKS BUT AND ALMOST KEEPS UP WITH MY 4 CELL NIMH SPEC2
OH YEAH!! MY SPEC1'S RUNTIME DIDNT REALLY DECREASE BY A LOT...BUT, MY 4 CELL SPEC2 RUNTIME DIDNT GET A LOT MORE RUNTIME AND SEEMS THAT THE SPEED INCREASED, BUT THE RUNTIME DECREASED OR MAYBE REMAINDED ALMOST THE SAME..IT REALLY SEEMS LIKE THE RUNTIME IS SHORTER EVENTHOUGH I PRESS THE BUTTON TWICE FOR EACH INTERVAL FOR THE SPEC2 CHARGER..
I THINK YOU SHOULD EXPERIMENT TOO AND TELL ME WHAT YOU THINK??
NEXT QUESTION..
WHAT ADAPTER CAN I USE FOR THE SPEC 2 CHARGER..RIGHT NOW IM USING ONE OF THOSE UNIVERSAL CHARGERS AND SWITCHED IT TO 9V MODE AND SO FAR IT WORKS GREAT.. THE ADAPTER GOES UP TO 12V BUT ITS SWITCHED ON TO 9V.. THE ADAPTER SAYS THE CURRENT IS 300MA .. IS THAT OK?? PLEASE LET ME KKNOW..THATS WHAT IVE BEEN USING FOR THE MEAN TIME WHEN I DONT HAVE ANY BATTERIES..
Old 09-02-2002, 03:06 PM
gertman's Avatar
I disapprove of mixing batteries like YOU DID AND THINK IT IS VERY STUPID AND RECKLESS!!!!! I suggest you be VERY careful when charging, since you are only using a timed charger, keep tabs on the temperature NiMH do not like heat!
YES, of course NiCd sells have more punch than NiMh's but less run time. I didn't realize you didn't know this. O, please report back what becomes of this hybrid pack. Let's see what it does long-term.
The reason why you have not seen much improvement on run time of your 4-cells is because you have not cycled your pack to regulate the voltage..................this is why your hybrid pack STILL works!!! I believe you are not charging the batteries enough, which is good in your case, this is why IT still works.
Let me give you a word of advice: when some one tells you specifically NOT to do something and you have the guile to go and do it anyway, don't come back and ask for advice about it!!!
O and one more thing, the next time you write a post in all caps I will NOT answer it!!!
Old 09-02-2002, 06:51 PM
Micro RC Innovator
Smile Dont be mad GERTMEISTER!! I think youre a cool helpfel dude!!!!
hey gert!! dont be mad gertmeister!! i think youre a cool dude!! i just was stubborn and wanted to try it out anyways so my spec1 would still be running and not out of comission since i took the nimh cell out of it and used it for my 4th cell on my spec2..you know...
i already knew that nicads offer more power and thats the second reason why i tried it out.
i just wanted to inform you that the operation went smooth and wasnt trying to disprove you..
anyways, youve been a big help and just wanted to thank you just i case i have'nt by now...
Old 09-02-2002, 10:37 PM
tinyrc's Avatar
MicroRCracer, if we were saying "don't take the tires off" or something like that, then it would be one thing, but this is more like "don't touch that hot stove or stick your finger in that socket" - you really should not mix these cells no matter what, even more so given the way that you are charging them. Please be very very careful, as you're likely to end up with a leaky or exploded cell on your hands (literally).
