01-25-2003, 03:54 AM
so you wana do wheelies?
i little bit of work but it costs about 7$ to do this mod to about 100 cars. you wouldnt believe how much it improved everything to do with the drive train. it is soo smooth.
01-25-2003, 05:32 AM
How does puttying the axles permenantly in place help you do wheelies?
01-25-2003, 10:34 AM
lol it looks likle you ****ed ur car up
01-25-2003, 10:46 AM
TinyRC Hacker
if you wanna wheelie without a wheelie bar and your putty, do my 3 cell mod, you wont be dissapointed. what dissapoint me though is that it likes to flip over alot which pisses me off.
honda accord wagon (3 cell ni-Cad mod, z-cars r/c 3.0 motor, shen qi wei chassis)
toyota bb open deck (dual cell 100 mah mod, shen qi wei motor) microsizer
lancer (3 cell mod, 150 MaH)microsizer
subaru wrx (1 cell mod, 3.0 volt li-ion) microsizer
01-25-2003, 01:12 PM
Bravely Runs Away Away!!
i think he has some...tube slipped in there?
01-25-2003, 02:39 PM
survey says!!!!!!!!!!
01-25-2003, 09:17 PM
Doom doom doom doom doom
wut kind of putty should u use
01-25-2003, 09:23 PM
i used jbweld. epoxy with metal in it. the tube is a qtip
01-25-2003, 09:28 PM
when put putty on it u cant change axles...right?
cuz i want to change my axles evry once and a while and still do wheelies.
i have an R-Spec the fastest gears and hard tires and it still doesnt wheelie!!!
01-25-2003, 09:31 PM
well im also using 2 batteries. but no you cant change the axle very easily. i guess you could cut the epoxy. i think im gona have to reseat one of mine. im not happy with the tolerance. this is a very usful mod. especially if you have dual batteries. it runs much smoother.
01-25-2003, 09:34 PM
well im not puting in a dual cell cuz i dont kno how to make a charger for 1
01-26-2003, 07:45 PM
ok it is possible to switch axles. i cut the top layer of epoxy off and you can pull the tube out and wedge it back in there. im probably gona put more epoxy over it tho.
01-27-2003, 07:22 AM
Im a cat, miow.
Hogjowlz rather than cutting away the epoxy, u could pull a wheel from the axle and slip it off.
Then glue the wheel back to the axle after!
I only recommend this tho if uve done a 3cell mod, cos it loosens the wheel a lot ne way, I wouldnt do It 2 a nice axle!
just a thought!
So what do u lot think?
Post it!
01-27-2003, 07:36 AM
i could do that but id be afraid the axle would wobble. if i can find a metal tube that fits the axle perfectly i will have to do that tho.
01-27-2003, 07:39 AM
Im a cat, miow.
Theres got 2 b a better way for theses axles.
Mayb a snap on/off axle holder?
or a peice if plastic that glues on,and can be snapped off easily.
So we could change the gears.
Post it!
