01-23-2003, 03:40 AM
Wild & Booster & 4CH Bit controler
Hi,
Just got my Wild Bit.
Yes the Wild has a Booster PCB, like the booster set !
The 4CH controler can control the Wild (and you can get two speed !!!!)
The Wild Controler can control a booster bit, but with turbo always on !
Anybody know how to add the action button in a 4CH controler ??
Danke
e_lm_70
01-23-2003, 04:37 PM
there is a switch on back with A'B'C on it
A= does nothing
b= works truck(half speed) & turbo button(full speed)
C=works truck (full speed) & weapon by turbo button
mine has 2 batteries & with out pressing turbo button it's still faster than standard wild c g but press turbo & it goes nearly as fast as car with 2.2 motor
01-24-2003, 02:32 AM
Maybe I will go for a 2nd bat too !
But I want to have the action button on my 4CH TX ! It should be just a pin to put to ground or +Vcc, close to the center IC !!!!
Anybody has found it already ???
e_lm_70
P.S: Now I can light on/off on my booster bit, using the Wild TX ....
Going to have a booster LXX soon, I guess the PCB should be 100% compatible with the Bit !
01-27-2003, 08:26 PM
Known Prick
01-29-2003, 08:12 AM
Known Prick
My new booster cars use another TX/RX chip combo. The TX6C. Check your controller. If it uses the TX6C chip, try a momentary on switch between pin 15 (Function 1) and ground or between pin 9 (Function 2) and ground. One of these should be the "action button". As my older TX's will not control my booster cars or my Wild Char-g's, I can only conclude that both use the TX6C chips. The Wild controller uses a COB package instead of an IC. I'm gonna try and add the booster function to my Wild. But, backwards. The boost button will engage the slower (creeper) speed mode as Wilds are already plenty slow.
Another intresting option listed on the data sheet for the RX6C is the turbo inhibit on left and right input. Could be used to automatically switch to un-boosted when turning. Just gotta find pin 11 on the RX..yeah right.
Here's a link to the datasheet:
http://www.arestek.com.cn/Datasheet/Tx6CRx6CE(v1.04).pdf
01-29-2003, 08:15 AM
Known Prick
"P.S: Now I can light on/off on my booster bit, using the Wild TX ...."
Where is this output on the RX?
Thanks!
