01-22-2003, 01:50 PM
Fullsize Wheelset Help!!!
Can some one please tell me why the pins always come out bented when I try to hammer them out with a nail and hammer!!!
01-22-2003, 02:05 PM
Kid at Heart
i donno..
in fact the only insight i can give on this subject is that when i remove the pins i grab the head of the pin with needle nose pliers. they seem to come out easily enough to me.
Doug
01-22-2003, 02:15 PM
I used a soldering iron to heat the pin. then quickly pulls the head with a set of plyers. the only prob i run into is the replacement wheels. i tried putting some on that i got off a rear axel, but i cant get the wheels to run stright. the car keeps pulling from one side to another. i dremmeled the body so they fit, but the friggin thing will not roll right. any segestions?
jack of all trades master of nothing!
01-22-2003, 02:18 PM
Kid at Heart
you took both wheels off the same axle?
if so did you either trim the spacer off the non gearside wheel or add a spacer to the gearside wheel?
other than that maybe your pins are wobbling loose i donno
Doug
01-22-2003, 02:25 PM
i trimmed the spacer on the nonspur side and the two lil-pin looking spacers on the spur side and it still was being pain. what wheels do you all use when swapping?
01-22-2003, 02:33 PM
Kid at Heart
bit rear wheels
i just use a set of rear wheels like you do. hmm this requires some research. let me look into this a bit.
Doug
01-22-2003, 02:54 PM
i used a kit racer rear axle. so i used two rear kit wheels for my full size wheel mod. but i had to tear up two axles to get the two wheels with spacers then i just filed them down to size.
rabbitsperm
01-22-2003, 04:21 PM
I imagine the hole for your axle shouldn't be too big either.
That could cause wobble.
01-22-2003, 07:23 PM
Blitzer Sonic
Hammering the nails in OEM cars is a lot easier. Because of the lack of quality, the nails aren't secured as well. That's what I did, and I now have a full size wheel set. Only drawback is that the front wheels touch my Mazda RX-7 body making it swerve to the left.
