Old 01-22-2003, 03:51 AM
GhoSStRyda GhoSStRyda is offline
spur gear
i just bought the "tuneup set" and im wondering what the Spur Gear is for? its the axle with hard plastic tires on orange gear....
Bit Char-G Automodellista Set
Love the Boost~~~
Old 01-22-2003, 09:49 AM
shocon2k
Its so you can use the drift axle set. Can you imagine having more axles than spur gears and not being able to have all your cars set up at one time...instead needing to swap spur gears in order to use them?
Old 01-22-2003, 11:10 AM
zclonedude's Avatar
zclonedude zclonedude is offline
i've no idea whats goinon
what's the drift axel set???
Old 01-22-2003, 12:46 PM
krillin52's Avatar
krillin52 krillin52 is offline
PLOOP!
Send a message via AIM to krillin52
i gotta ask, which suspension is which?
Old 01-23-2003, 03:15 AM
frizzen frizzen is offline
Tool User
Drift Axle set is a setup which lets you have almost no lateral traction on the rear-end. So the car can donut like you wouldn't believe, but can still accelerate pretty well. (Lack of lateral traction at rear axle results in Oversteer) Combine that with some really hard front tires and you can 'drift' corners. It's gonna take some practice to really get good at doing it; but when you do, it looks wicked.
If I remember correctly, with the suspension bars, the fewer holes in the bar the less it lets the steering nuckles move up and down. And the more/larger holes let it move more. (think like anti-sway bars: the harder it is the more it resists the weight transfer to the outside wheel)
Wheel Weights! Steve ZipZaps Monster Truck 54 05-24-2006 12:40 AM
"the need for speed: a fast MT gearbox" chilli_mp138 ZipZaps Monster Truck 1 12-20-2005 05:58 PM
The maximum gear ratio..... charliebrown ZipZaps 9 01-13-2004 03:55 PM
fix the faulty ball diff's spur gear miketre Mini-X 2 12-29-2003 04:18 AM
spur gear 2000-redrider Dynamite Rocket Racer Parts and Hop-Ups 2 01-03-2003 02:52 AM
