01-20-2003, 05:54 PM
Im a cat, miow.
Long Wheelbase or Short?
Im currently doing an internal tricell bit, shall I place the batteries so that the car is longer or shorter? I have cut the chassis and half and will glue polycarbonate to both ends.
Does a longer or shorter car handle better?
So what do u lot think?
Post it!
01-20-2003, 06:06 PM
'00 Subaru Impreza 2.5 RS
I think the longer will handle better. The Zip Zaps are longer than the Bits, and they handle a bit better, but that may have to do with other aspecs of the ZZ besides the wheelbase. What are you going to do about bodies after you alter your wheelbase?
27MHz Microsizer White Peugeot 206: 3.8, NiMH
49MHz Microsizer Yellow Lancer Exolution: stock
27MHz LXX Char-G Xanavi Skyline GT-R: 3.0
27MHz ZipZap Yellow F&F Civic: 2.6, Carbon Fiber-look hood, lowered, sport tires, turbo gears
01-20-2003, 07:00 PM
Im a cat, miow.
I will cut them and lengthen them with modelling epoxy putty or JB WELD.
Post it!
01-20-2003, 07:12 PM
A longer wheelbase will make the car more "stable" when driving but will create a bigger turn radius. The shorter wheelbase will be more nimble and sharper turning. Think of the difference between an old Lincoln Towncar (boat of a car) and a Miata. HTH
01-20-2003, 07:14 PM
Im a cat, miow.
Good way of thought there! I think Ill only extend the chassis 4mm then!
Post it!
01-20-2003, 11:03 PM
That's all folks
Hey, just try a Zip Zap chassis. Three cells fit in without mods, just flip the circuit board over so components are on top. I would suggest a PCB other than a stock Zip. I have clone or bit boards in all my Zip Zaps with 2 cell mods and the stock chassis covers on them.
That's all folks!
01-21-2003, 05:53 AM
Im a cat, miow.
Only prob is that zip zaps aren't sold in the uk!
Post it!
01-21-2003, 06:18 AM
You can't beat it.
I have an idea for the body, once your done, go on Ebay and bid on a Zip Zap body. There's even a Porshe 911 body you can get.
One Ferrari Enzo.
One Mercedes SL600.
1 Mitsubishi Eclipse.
Two 95' Mazda RX7s.
01-21-2003, 08:22 AM
why do you need 3 batteries? its hard to control with 2 batts installed.
01-21-2003, 08:30 AM
Im a cat, miow.
Have u ever tried 3 cells hog?
its FUN!
But not much good if ur steering is a bit messed up!
Post it!
01-21-2003, 08:33 AM
i like to be able to sort of control my vehicle. it barely does that now with two.
01-21-2003, 09:03 AM
Im a cat, miow.
yeh,but make it faster,upgrade the steering,fatten the wheels,and it will handle!
Post it!
01-21-2003, 09:13 AM
how the heck do you fatten the wheels? i dont have any cheesburgers that small.
01-22-2003, 10:32 AM
Im a cat, miow.
Americans can put fat in nething! Just like us in the UK!
Transplant some wheels off a toy model car or something!
I bought a bit motorbike,the pcb is like a clone, and I might put its wheels on my bit!
Post it!
