01-20-2003, 04:25 PM
SHYMERLOO!!!!
bakward pinion gear?
What IM rUnnin
white toyota supra with:
All Wheel Drive
ball bearing upgrade
light set
stage 2 motor upgrade(blue)
nimh cell upgrade.
ENS (electric NOS simulation)
smoke exaust
fire exaust(optional)
!!!!!!!!SCREAMS!!!!!!!
01-20-2003, 04:48 PM
try it
01-20-2003, 04:51 PM
MASTER PAINTER
not the pinion gear backwards
take the IDLE gear, and secure it onto the motor(with glue or a wedge of paper)
that will make it faster, but you will have less torque, and pressing forwards will make it go backwards, pressing backwards will make it go forward
01-20-2003, 05:25 PM
Bâshbad the Wicked
All that flippin the pinion really does is better securing the idler gear if it wiggles around. (Came like that on 1 of my clones)
Stay out of the DAYLIGHT!!!
01-20-2003, 05:54 PM
TinyRC Sith Lord
yeah i noticed that all the clones came with the pinion gear mounted backwards on the motors. i think its done to prevent some kid from losing the idler gear if he/she takes off the axle.
Mine: red S2000 27mhz
Hers: blue subaru WRX 45mhz
Mods:
2.6 motor
8.25:1 gear axle
medium tires/soft stabilizer bars
l.e.d headlights
rare earth magnet
01-20-2003, 06:22 PM
Bâshbad the Wicked
I was actually thinking it may have to do with the cheap construction of the clone. The clone of mine that has the backward pinion also has an idler that shifts back and forth a wee bit too much. I noticed when a motor is in with the pinion facing forward/outward, what have you, the idler gear rubs against the tire, and loses contact just enough with the pinion to halt the car.
babblebabblebabblebabblebabblebabblebabble
I'm the only person that most people know that can make a short story looooooong. hahaha
01-21-2003, 12:31 PM
Just kinda burned you...
So this is also applicable to "legit" Bits too?
"I won't lose, no matter what, because the prize is a full tank of gas." Takumi
01-21-2003, 12:51 PM
i run all my cars with the pinion gear as you say "backwords" i even cut a few down. the less horizontal slop the idler gear has the less energy is wasted.
01-21-2003, 01:28 PM
Fear the 1's and 0's
I'll go along with the above. Got all mine set "backwords".
No it doesn't make it run noticeably faster if at all.
But i have lost a gear on a genuine bit once, so heck this came up as a possible way to eliminate lost idler gears.
01-21-2003, 01:36 PM
there is a noticable difference in torque and acceleration when you limit the slop of the idler
01-21-2003, 08:06 PM
mine appeared to accelerate faster and have a higher top speed
01-21-2003, 09:01 PM
That's all folks
Zip Zaps come with the pinion "backwards" too. I found that on some car/motor combos, that the raised edge of the pinion will ride on the spur gear if you do not put the pinion "backwards".
That's all folks!
01-21-2003, 11:25 PM
Less torque?! Try like 1/25th as much torque. Consider that standard gears are like 9.something to 1 ratio. Flipping the idler onto the motor and taking out the pinion would reduce the ratio to like 1.something to 1. Basically your motor would be trying to turn your wheels at 20000 rpms or whatever, which is a theoretical speed far beyond what is possible.
