Old 01-19-2003, 08:11 PM
Wrecks Inc Wrecks Inc is offline
Send a message via AIM to Wrecks Inc
Why is this?! 2.6 is SLOWER then 1.0
Yup..got my microsizers today..got the rtr set with the 1.0 motor, and then the speed set with the 2.6 motor, gears, and ribbed tires. Now, for some reason, the 2.6 is way slower then the 1.0. Less torque as well. What is wrong with it?
Wrecks Inc....We meet by accident!
Old 01-19-2003, 08:22 PM
NoPropMan's Avatar
NoPropMan NoPropMan is offline
{{ x | NO CARRIER
That is crazy.
What gears are you using? Even with the "power" gears, the 2.6 should be quite zippy.
I would suggest you run the motor continuously for a period of time (turn the chassis upside down and let it run) and then try it.
Old 01-19-2003, 08:27 PM
sessiz10's Avatar
sessiz10 sessiz10 is offline
Told ya.
Okay 1st you're not mixing them up right? The 2.6 is orange and the 1.0 is blue.
There could only be two other things wrong.
1. You got a bum motor, try cycling it a couple of times (put car upside down and run the car dry) if there is no improvement return it or see if you can get a replacement.
2. The motor isn't making contact well with the car. The pinion can be off, not conecting well with the gear. The tab on the motor isn't making a good conection with the car hence not getting enough power. Spin the little tab around so that it's pointing towards the front of the car, and then try towards the back, and so on position wise.
I hope this helps.
____________________
Meh.
Old 01-19-2003, 08:33 PM
Thanks guys! I am just going to cycle it..(would it be possible to just hook it up to a battery?) Thanks again
Old 01-19-2003, 08:57 PM
Impreza WR reX's Avatar
Impreza WR reX Impreza WR reX is offline
<(- -)> <- Yoda
I have similar problems with my 2.6 I already ran it upside down 5 times & still no improvement. I think the motor is just defective. It came with a Bit Char-g, should I email Tomy or Hobbico (I don't speak Japaneese)? Any other way I can get a replacement? Any help appriciated.
Old 01-19-2003, 09:03 PM
NoPropMan's Avatar
{{ x | NO CARRIER
Impreza WR reX:
If it's an official Tomy 2.6, I would e-mail Hobbico and tell them it's defective. They will probably send you a new one.
Their customer service e-mail address is rcfun@microsizers.com.
Old 01-19-2003, 09:17 PM
<(- -)> <- Yoda
thanks nopropman,
I just moved the connection tab back again and it seems to be working now! I want to compare it with someone elses though, just to make sure that it's up to par with other 2.6's.
Old 01-20-2003, 11:31 AM
<(- -)> <- Yoda
Ok, looks like it's back to the replacement thing! The connection tab broke off when I pulled it back this time . I didn't realize it was so thin. Do any of you think if I put a little bit of soilder or something over the point, it would still work?
wooo hooo!
Old 01-21-2003, 11:01 AM
dohc's Avatar
dohc dohc is offline
TinyRC Hacker
no, but ask here if they can sell you there spare part that you need
honda accord wagon (3 cell ni-Cad mod, z-cars r/c 3.0 motor, shen qi wei chassis)
toyota bb open deck (dual cell 100 mah mod, shen qi wei motor) microsizer
lancer (3 cell mod, 150 MaH)microsizer
subaru wrx (1 cell mod, 3.0 volt li-ion) microsizer
Old 01-21-2003, 11:15 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
2.6 motors are weak.
Old 01-21-2003, 07:14 PM
Hog, thats exactly what Im thinking! The 1.0 is so quick! I cannot beleive it! lol
Interesting / Weird motor issues...Celica 2.6 vs. RX7 2.2 Suntzu28 Bit Char-G / MicroSizers 3 01-08-2003 07:49 AM
1.0 Motor tino Bit Char-G Parts and Hop-Ups 7 01-01-2003 04:48 PM
bit racer 2.6 vs. bit char-g 2.6...differences? spikeymike218 Bit Char-G Parts and Hop-Ups 2 12-20-2002 04:13 PM
2.2 vs. 2.6 vs. 3.8 Namuna Bit Char-G / MicroSizers 14 08-23-2002 09:30 AM
2.6 motor and 2.2 carver Bit Char-G / MicroSizers 15 08-04-2002 05:06 PM
