Old 01-19-2003, 12:12 AM
AzNRiCeBoY AzNRiCeBoY is offline
Unhappy 4-band controller is NOT working
does the tomy 4-band remote only work with booster bits? cuz for some reason, it won't work with either of my 27 mhz bits. i checked the frequency switch and it's set to 27mhz. i even tried switching it to all the other frequencies. am i doing something wrong?
Old 01-19-2003, 12:20 AM
AzNRocket's Avatar
AzNRocket AzNRocket is offline
AzN InvAzN
What letter did you put it on. If you have a regular 1 speed car put it on A. there should be a switch on the back to do so.
Celica :
Auto Modellista Set:
OtheR RyDes:
Bensu Bullet Mercedes
Bensu Bullet fOcUs
Old 01-19-2003, 12:29 AM
thanx a lot for the help! it turns out that setting it to A worked. i thought i tried all three, but i guess i didn't reset the remote every time switched it. thanx again. now all i need to do is figure out how to expand the range on it. i think i'm gonna try the telescopic antenna mod. is there n e thing else i can do?
Old 01-19-2003, 02:26 AM
Fourustwentius's Avatar
Fourustwentius Fourustwentius is offline
Help Me!
Remove the cripple capacitor check questformadness.com
At the bottom.
Old 01-19-2003, 10:42 PM
bdebde's Avatar
bdebde bdebde is offline
That's all folks
Try this antenna from Radio Shack:
270-1409
Had to drill one hole in the base and it fit great into my 4 band controller. No solder no hassle, even kept the original antenna coiled down inside (just in case the mod didn't work). Just had to notch plastic for it to fit through, screwed it in with the original antenna screw. I get a lot better range with it now.
That's all folks!
Old 01-24-2003, 08:24 PM
uguu
So how much range do u get with this controller (unmodded) and without the capacitor? I'd like to increase the range of my Mach 5 and Skyline using this controller. Also where'd u order the controller from?
Old 01-24-2003, 09:22 PM
bdebde's Avatar
That's all folks
Unmodded I got about 15 feet (not exact) range. It is probably double with mod. I never did anything with capacitor. Also some frequencies and/or different cars seem to vary as well. I got mine from a hobby shop in Renton, Washington.
That's all folks!
Old 01-25-2003, 11:28 AM
ZeroTT ZeroTT is offline
I didn't think there was a crip cap on the 4-band...at least not one anyone knew about? You might also try wiring in a 3rd AA battery to the controller. I hear that increases range significantly, though it might make the controller a bit uncomfortable. I don't think it would hurt the car when charging, since the controller regulates the voltage normally. I'm planning to wire one in today using a Radio Scrap 1AA holder.
(WRC body)
"It is not the spoon that you wish to bend, but rather, the will of the spoon..."
Not working kewlguy ZipZaps SE 10 12-23-2005 04:54 PM
No wonder my Layman's Tricell wasn't working! charliebrown ZipZaps 1 01-26-2004 04:17 PM
will trade for working 49mhz ZZ chassis rt450 For Sale/Trade 0 07-07-2003 01:01 AM
PCB Not working (Strange Dual battery symptoms) kenny_dilger Bit Char-G / MicroSizers 0 12-16-2002 10:59 PM
