Old 01-17-2003, 11:34 PM
crazydave's Avatar
Garage Rocker
Had a problem slamming 911 body, how's this look?
I slammed my 911, had to dremel at the rear wheel wells quite a bit, and my PCB is being held down by electrician's tape. It looks way cooler now though. You think?
Here's the problem, the back had hairline cracks where the screw that holds the motor in smashes against it. I was afraid the plastic would chip away when I cutthe slot, and it did.
I covered it with a little license plate. Does this work? I know it's a little large, but I had to cover my mess.
Crazy Dave's Crazy Car Gallery-It's crazy man, dig it.
Old 01-18-2003, 09:50 AM
Canadian Bit's Avatar
Canadian Bit Canadian Bit is offline
You can't beat it.
I think the license plate should be removed because it's too big and it should be replaced with modelling putty in the cracks. Smooth it out, so it blends in.
One Ferrari Enzo.
One Mercedes SL600.
1 Mitsubishi Eclipse.
Two 95' Mazda RX7s.
Old 01-19-2003, 02:14 PM
metsrule119's Avatar
Actually, they suck^
not bad... it looks better since its lower... take off the plate and put some putty in the cracks- it'll look way better
Old 01-19-2003, 04:41 PM
NitroBurner NitroBurner is offline
Send a message via AIM to NitroBurner
I had the same problem trying to lower my Civic and ended up throwing the bod away it was soo hacked up.. Its hard lowering a ZipZap for the first time.. I think RadioShack needs to produce a body that comes with enough room for lowering like a Suburban or Escalade body..
Old 01-21-2003, 04:26 PM
Wreck Inc 2
that looks pretty sharp except for the black lines
Problem, body related? xmodsupra XMODS Parts and Hop-Ups 3 11-30-2003 08:51 AM
Weird body problem geofroley Bit Char-G Mods and Projects 1 11-21-2003 11:56 AM
custom body problem BigBut4 XMODS Mods and Projects 1 11-11-2003 10:11 PM
Porsche 911 body Canadian Bit For Sale/Trade 10 01-24-2003 07:36 PM
Putty body kit problem Ghost of Akina Bit Char-G Mods and Projects 1 10-27-2002 08:53 PM
