Go Back   TinyRC.com > 1/64 and Smaller > Digi Q > Digi Q
Old 01-17-2003, 08:11 PM
mattdaxlr8er mattdaxlr8er is offline
Calling Keal!~
hey, my digiq doesnt turn 2 the right as much a to the left. I know that keal knows alot of codes now after trying most of them. Do you know any codes for the special propo which allows the car to turn more right?
bubble car.
Old 01-17-2003, 08:14 PM
tinyrc's Avatar
tinyrc tinyrc is offline
What about the steering trim feature?
Old 01-17-2003, 10:59 PM
yes, but the more I adjust it , the more it turns to the right than the left. I want to independtly adjust it.
bubble car.
Old 01-17-2003, 11:50 PM
keal
matt,
There aren't any codes to let you adjust the wheels seperately.
If your car used to run straighter and it's suddenly turning more to one side, maybe you have carpet fuzz or something stuck in the tires? You could try opening the car to check it out.
I would think you can adjust the steering trim on the controller
in the other direction to get the car to go straighter. But that's the only other thing I could think of. My Cox Beetle turns to the right really sharp, and when I adjust the trim, it's almost all the way to the 'L' to make the car go straight.
I hope you can get your car going straight with the trim!
Old 01-18-2003, 01:18 AM
yea, thx keal. It goes staright for about 2 feet then starts to curve left. weird. How bout the steering of the nsx? do u hav 2 adjust it?
bubble car.
Old 01-18-2003, 03:54 AM
keal
Matt,
No, once I set my NSX-R's trim on the controller, it stays straight all the time. My Cox Beetle is different, though. I have to adjust the steering every few minutes. Actually the Beetle never seems to be able to go very straight.
Hopefully someone has the same experience with this problem and can give you some answers. I would also like to be able to tune-up my Beetle!
Old 01-18-2003, 03:08 PM
keal
Lightbulb DigiQ Front Wheel Shaft Mod
Matt, this morning I was checking out the Japanese DigiQ sites and found this single page showing what some people to help fix their steering:
It appears that they make or buy some sort of metal shim, and by placing it on the top of the front wheel shaft, it holds down the shaft better so that the up-and-down movement of the wheels is limited. If you look at the picture on the left, it shows the metal shim is holding down the shaft on the tiny knob part in the middle. The picture on the right shows the person has split that part of the shim, and spread the two resulting flaps to the sides of the knob. This must have a different effect on the car.
Since my NSX-R has no steering problems, I thought of taking out the front wheels, and putting it in my Cox Beetle to try out. I found that the shaft is different, and you can't swap them! The NSX-R shaft is a lot thicker near the wheels, and the center knob is gone. Instead the knobby part is molded into the chassis of the NSX-R. Now I'm thinking that my Cox Beetle really needs to be modded.
Well, now I'm on a mission to make one of those shims! If I can figure out how to make it soon, I'll definitely post results and how to make it
Matt, there's hope for our wobbly cars!
Calling All ZipZap Body Modders..... DarkTari ZipZaps 2 08-22-2003 11:56 PM
Calling All Modders Swavey Bit Char-G Parts and Hop-Ups 4 07-29-2003 01:56 PM
Calling All Modders nrmcj Bit Char-G / MicroSizers 20 05-20-2003 01:37 PM
Calling Xatu! Rcmaniac246 Miscellaneous Discussion 8 04-26-2003 12:34 PM
calling all mid-west dragon4450 Bit Char-G Mods and Projects 9 03-20-2003 11:12 PM
