Go Back   TinyRC.com > 1/24 and Smaller > Dynamite Rocket Racer > Dynamite Rocket Racer Parts and Hop-Ups
Old 01-17-2003, 03:36 PM
misterbungle misterbungle is offline
Send a message via Yahoo to misterbungle
Arrow Pinion Gears
Does anyone know where to get some metal pinion gears for my DRR? Preferably 13-14 tooth. Seems like Horizon Hobby is selling out their stock fast, I can't seem to find them there anymore. Also, this may be a silly question, but, can you get metal spur gears as well?
Old 01-17-2003, 05:01 PM
Krabill Krabill is offline
This guy has them:
http://www.precisionmodelproducts.com/id34.htm
Old 01-17-2003, 05:30 PM
Thanks a million! But how the heck do I order from that ninja?
Old 01-18-2003, 12:28 AM
dtmracer dtmracer is offline
DONT get metal pinions. they are terrible, unless ou never plan on changing the gear ratio on your drr. once they are on its a pain in the butt to get off, unless you have a pinion puller. plus they weigh more get some mini 4wd pinions, ive never had one fly off and they clean up like new with rc car motor spray. they come in packs of 5 for 2.50 at ultimate hobbies in orange. they come in sizes ranging from 8-18 t
Old 01-18-2003, 04:53 AM
fastboy fastboy is offline
im a micro daddy...
Send a message via Yahoo to fastboy
hmmm...the metal pinions i have are a grub screw fitment like larger scale ones and cause no problems in removal and fitment,the plastic 4wd fly off mine with an hpi 45t mod in and 7.2 :0
dave
uk
Old 01-18-2003, 10:15 AM
Tch0rT Tch0rT is offline
My plastic stock pinion keeps flying off now that I added 7.2v on a Micro RS4 Motor... it's extremely annoying. Regarding the teeth on the pinions, which ones are suited for which purpose (top speed, acceleration, etc)?
Thanks,
Ryan
Black NSX GT1 Dynamite Rocket Racer
7.2v BLiND Batteries Battery Pack http://www.blindbatts.com
HPI Micro RS4 Mod 45T Motor
HPI Micro RS4 14t Pinion
ABC DTM Bearings
ABC DTM-SP Foam Tires
Dynamite Aluminum Body Posts
Foam Insulation Home Made Bumper
31MPH or 50 km/hour
Green Lamborghini Murcielago MicroSizer
Rare Earth Magnets & Steering Spring Saver Mods
Old 01-18-2003, 01:17 PM
I was also wondering if the Micro RS4, Mini Z, or any other brand of pinions will work with the DRR stock spur?
Ryan
ABC DTM Bearings
31MPH or 50 km/hour
Old 01-18-2003, 01:54 PM
im a micro daddy...
i use hpi rs4 pinions,altho a little too long(they can rub against the rear tyre,i filed mine a little with dremel and work great.
dave
uk
Old 01-18-2003, 06:25 PM
get okami or Jtech plastic pinions from ultimate hobbies. they go on really good and tight. i run the coreless micro motor and it has never come off. they work great. as for pinion sizes, bigger pinion = more top speed, less acceleration, smaller pinion= more accelleration, lower top speed. for my car i ran the biggest pinion i could find. even with the stock motor i ran a 17tooth because these already have so much acceleration and breaking tires loose alot will harm your stock esc. you will proboly need a heat sink if you go to the 17- 18 tooth pinions. thats another bad thing about the metal pinions, they come in such small sizes.
Old 01-18-2003, 07:49 PM
What's the web page for Ultimate Hobbies? I went to a www.ultimatehobbies.com but couldn't find the Pinions you're talking about.
Ryan
ABC DTM Bearings
31MPH or 50 km/hour
Old 01-18-2003, 08:13 PM
ultimates website dosnt have much on it. call them, and order over the phone. just ask to order "MINI 4WD car parts" then ask for the pinions. their phone number is (714) 921-0424
Old 01-19-2003, 10:13 AM
i want some pinions....can anyone tell me where to place an order on this page/site....i'm lost.
Old 01-19-2003, 03:07 PM
Heya Misterbungle,
Try going through the main page www.precisionmodelproducts.com or here's a direct link to the 1/24th scale upgrades http://gallery.bcentral.com/Gallery/...59&Dept=220806 watch out on the shipping though. I was going to order the 4 piece Foam Tires with Wheels that are $9, the shipping was $10! I'd probably only order from them if I was buying a lot from them.
Ryan
ABC DTM Bearings
31MPH or 50 km/hour
Old 01-20-2003, 08:35 AM
ag04 ag04 is offline
Send a message via AIM to ag04
DTM racer, how fast is that coreless motor? I would think that it would be almost too fast to handle, with those higher RPM's and all. I have a micro modified, and 7.2v and that is already fast enough. on the pinion subject, I use the stock pinion from the mini stock on the mrs4 micro mod motor, it never comes off, and it is a very very tight fit, I had to make a hole a bit wider with my xacto knife. how much speed would you guys say a 13 or 14 tooth pinion would add, compared to a stock 10 tooth one?
ag04
Old 01-20-2003, 01:22 PM
2000-redrider 2000-redrider is offline
Assuming that your motor reaches 30,000 rpm and your using a 42T spur, you should expect about a 7-10 mph increase with the 13T or 14T pinion.
pinion gears ml22 Bit Char-G / MicroSizers 0 02-23-2003 11:55 PM
Pinion Gears Pojo Bit Char-G / MicroSizers 2 01-11-2003 12:28 AM
pinion gears arceeguy Bit Char-G / MicroSizers 11 01-07-2003 09:41 PM
What is the difference in the pinion gears? Redfire Bit Char-G / MicroSizers 7 09-04-2002 07:38 PM
