Go Back   TinyRC.com > 1/24 and Smaller > Mini-X > Mini-X Parts and Hop-Ups
Old 01-13-2003, 10:38 AM
HaCo HaCo is offline
Mini-Z Wheels...
Do Mini-Z wheels fit the Mini-X car...
Look here, nice alloy wheels...
HaCo
Old 04-07-2003, 05:31 PM
Mondo Mondo is offline
Z Wheels
Haco,
I own a few Mini-Z's, 7 to be exact.
Unfortunately the Mini-Z wheels do not fit the Mini-X.
I have looked into perhaps modifying them to fit, but it is too much work and the Mini-Z has a smaller diameter axle too, it is too bad they don't fit, as the Mini-Z wheels are available in 9mm wide (same as Mini-X) and 11mm wide.
The Mini-X's wheels are crap and the tires even worse.
Second place is first loser...
Old 04-10-2003, 06:45 AM
Kid_Cojonez Kid_Cojonez is offline
Send a message via AIM to Kid_Cojonez Send a message via Yahoo to Kid_Cojonez
Is it possible /feasible to modify the Mini-x axles to take Z wheels??
(custom parts maybe, tinyrc??)
Old 04-10-2003, 08:09 AM
Re: Z Wheels
Kid_Cojonez,
That sums in up...
Old 04-15-2003, 07:49 AM
turtle's Avatar
turtle turtle is offline
I shall call him Mini-Me
wut if u have acsses to a machine shop?
future car: white 1966 Pontiac GTO
Old 05-11-2003, 11:06 PM
SteveK SteveK is offline
Send a message via AIM to SteveK
Mini-Z tires do fit the Mini-X wheels (At least the foams do).
Old 05-12-2003, 06:26 AM
Cian's Avatar
Cian Cian is offline
Got Cheese?
the two wheels aren't even close, I've looked into it myself. mondo's right!
Old 05-13-2003, 12:48 AM
Hooters Driver Hooters Driver is offline
You can make Mini Z wheels fit with only a small amount of work.
First, when using mini z wheels the wheel track will be widened by approximately .30" so you will need a much wider body or you'll have to do some customizing to your current body.
Second, you will need 4 plastic axle bushings (if you added real bearings to your kit you should already have these laying around). In each bushing cut a groove through the center of one side just wide enough to fit over the pin that goes through the center of your axle. Now insert and glue that bushing into the back of the mini z wheel where their bearing is supposed to go (leave out the outside mini z bearing). It's that simple, you now have a mini z wheel that can be bolted onto your mini x.
One final note, you will have to turn your wheel nuts around backwards so that the nylon portion goes on the axle first in order for them to fit on the mini z wheel. As the nut is tightened down onto the mini z wheel it will center the wheel onto your axle shaft.
One more thing. Remember: If an individual says something can't be done, it just means it can't be done by that individual - Michael Strother
Old 05-13-2003, 02:59 AM
Talking
Now Why didn't I think of that???
Old 05-13-2003, 10:26 PM
3series takumi's Avatar
3series takumi 3series takumi is offline
mini-eX-Driver
Send a message via ICQ to 3series takumi Send a message via AIM to 3series takumi Send a message via Yahoo to 3series takumi
simply savage
so simple, so savage!
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
Mini z OL with mini z monster wheels Mr.M Mini-Z - Mini-ZRacer.com 1 08-31-2004 08:02 PM
Mini x wheels Tbird Man Mini-X 0 10-09-2003 08:34 AM
Mini Z Wheels Newbster Epoch RC1/43 1 02-17-2003 06:19 PM
