Go Back   TinyRC.com > 1/24 and Smaller > Dynamite Rocket Racer > Dynamite Rocket Racer
Old 01-12-2003, 12:56 AM
ModemJunki ModemJunki is offline
Lightbulb Chassis Tweak! Pics!
Well, like most new DRR owners, I had to do some tweakin' to get them to run right. Ordered two from Ehobbies - and got two black cars. Both on Channel 3. Fortunately, I ordered a set of ch.6 crystals as well.
So, of course, the first problem was the oversteer to the left. Car would do mad spins leftwards but not rightwards.
Tweak #1 - the washer, placed underneath the steering knuckle.
Now the mad spins were not so bad, but it would still do it - mostly when the steering angle was set high (steering angle setting wheel on the controller handle). I took a closer look - the problem is the servo wire boot! If you have the steering angle set to max, the left front tire contacts the servo boot, effectively locking that one tire as shown here.
Tweak #2 - Simple fix - push wire back with finger pressure, hold for a bit, and it will stay back.
The cars (both!) still didn't track right. And one of the two was put together kind of poorly, it seemed, the rear end was noisy and rough. I began a complete teardown, checking every bushing and screw. While I was reassembling the chassis, i noticed something important: tightening the screws to the upper deck would tweak the upper deck off to one side! The holes in front did not line up to the king pins. Aligning it to the king pins would cause the car to rack (torsion flex/twist) to the side!
I think this is caused by the rear center mount not being "perfect" in form.
Tweak #3 - hog out the holes(see next pic) in the upper deck and the matching holes in the radio/esc box. This allows you to wiggle the chassis a bit, you're not dependent on the shape of the rear center mount for aligning the deck/radio box. Carefully reassemble chassis to eliminate torsion (took a couple of tries).
Be super careful not to hog the holes out too much. A half a millimeter is enough.
On the car that was noisy, it was just put together badly. I trimmed some junk off the spur and pinion gear, and I opened the diff up, as it's screw was all the way backed out. It really is kind of a poor performer. I found that using one of the orange donuts that hold the car body on during shipping made it work a bit better than the stock black O-ring. Somewhere in my garage I have a collection of tiny O-rings, I'll experiment with them in the future, and with some different greases in the diff itself. I also paid close attention to rebuilding the front end. Both were assembled in a way that required a lot of steering trim, I re centered everything (might was well do it right while you're in there). I'd like to find a way to make toe adjustable on these cars, I think this would make for some interesting handling possibilities (not to mention new ways to wear out your foams!).
Now the "bad" car runs great! Purrs like the other one (which I also did a tear down on, it was pretty much OK except the front end). The stock rubber tires are good on carpet, but on Armstrong linoleum they are a challenge to come out of corners with. Ran three sets of alkaline batteries through each car today, was a blast. After the first set, the motors seemed to run a bit smoother. Next I have to budget for a couple of sets of NIMh and a dual charger (or two chargers, anyway).
And I can tell I'm going to spend a lot of time cleaning these cars. Cat hair... yech. And one of our cats tackled the GT-1 as it passed by....
Oh, and a hint for the indoor racing crowd: pick up a bag of multiple-size bungee cords. Stretch them between table and chair legs etc. along the floor, and you'll have something to bounce off of when you get run under the couch/end table/ etc. by the competition (or your mad driving skilz).
Comments? Suggestions?
I'll shut up now....
Old 01-12-2003, 08:18 AM
catman25 catman25 is offline
awesome insight...please post more .if you have any more tricks...why not break the motor in the water way?my 2 are comming mon. :-)
Old 01-12-2003, 01:16 PM
I'm from the old-school "just run it" break-in crowd (keyword: old). These motors are sealed, non-serviceable units. Back when I raced slot cars (wayyyyy back in the '70s/'80s, whippersnappers! ) we used to break 'em in with slow-speed runs and "stock" controllers before going to full tilt running and the "hot" controller.
Either method will work.
After the break-in run, a drop of oil on each shaft bushing, wait a few moments, blot up the excess. That's it!
Old 01-12-2003, 10:22 PM
Krabill Krabill is offline
Sweet writeup
Mine should be at my doorstep Monday (tomorrow). I can't wait to tear that little booger apart
Old 01-12-2003, 10:34 PM
mine too via fed ex:-)
Old 01-13-2003, 01:36 AM
It'll be great to see what kind of quality differences you guys see in your cars. As I said, one of mine was really bad, the other was kind of OK.
Carbon Fiber, Trc/zero-p Chassis Pics Zero-Man XMODS Parts and Hop-Ups 344 09-03-2007 08:04 PM
Chassis Pics clrkp XMODS Gallery 0 12-27-2004 11:04 AM
Carbon Fiber Chassis WillS Mini-X 22 08-13-2003 08:17 PM
custom chassis production has started ronak26 Bit Char-G / MicroSizers 45 02-24-2003 04:18 AM
Detail pics of 4x4 chassis Widdler Bit Char-G Mods and Projects 6 01-30-2003 06:36 PM
