Old 01-11-2003, 10:47 PM
VuN86
precious painting???
hey guys i was just wondering if anyone knew what to do to paint the precious bodies but first i need to know how to remove the paint. i guess using nail polish remover is out of the question huh i hear alot of people say not to use it so what should i use?
secondly how would i go about painting it would i be painting from the outside cause the body seems a bit thick?
if i was to do decal stuff how would i do that just wait for the paint to dry mask it and cut out what i want with an exacto knife
glossy appearance what should i use to get a nice and glossy look?
sorry about all the questions and them be so unorganized i just kinda tought of things as i went along.
Old 01-11-2003, 10:48 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
The other "How do i get the paint off?" thread said to use pine-sol. haven't done it myself.
Old 01-11-2003, 10:52 PM
VuN86
o i just remembered something from painting lexon bodys i used to steel wool the car to get the paint to stick better would that be good to do or would it scrap up the body?
Old 01-12-2003, 12:32 AM
sessiz10's Avatar
sessiz10 sessiz10 is offline
Told ya.
1.Remove the paint, any method.
2.DO NOT USE STEEL WOOL!!!
3. Mask off windows and lights and anything else you want.
Here's where it gets tricky.
4.Paint it. you do not have to paint these from underneath just take it easy on the paint. Afterwards you can dip the car in future floor cleaner or spray it with a clear acryilic spray to get that high shine.
One tip I can give you if you wanna do splashes or flames is to paint the whole car that color first. Let dry over night. Then mask off the flames or splashes or stripes or what ever. Now paint the car the main color. Let paint dry fully before you remove any of the maskings.
I hope this helped.
____________________
Meh.
Old 01-12-2003, 12:34 AM
VuN86
how would i remove the paint and what paints should i use?
Old 01-12-2003, 12:42 AM
sessiz10's Avatar
Told ya.
I remove the paint by letting it sit in thinner for a few hours and then taking a toothbrush to it. The other method is the pine sol method (which I haven't tried yet) 1 warning on the thinner, do not wash the car with water afterwards, wipe it off best you can and let it dry, the water tends to cloud the plastic.
You can use any paint from enamels to acrylics. I use a spray can (I got my skills with the can from bombing walls as a teen) while some are more comfortable with bristol brushes and air brushes.
Experiment.
Meh.
Old 01-12-2003, 12:44 AM
VuN86
does rubbing alcahol work well? sorry i don't know how to spell it i don't touch that stuff.... well except for on new years
Old 01-12-2003, 04:09 AM
Spanky's Avatar
Spanky Spanky is offline
Mr. Goop
Steel wool... steel wool works on larger lexan bodys because youpaint the bottom of the body, so you can essentially use a flat paint. the top of the body is still the glossy plastic/lexan. so only use steel wool if your painting on the bottom of the body.
i used rubbing alcohol to take the paint off mine... and an old toothbrush. due to the thickness of these bodys i would not recommend painting the underside of them. paint the outsied/top and then when your done, spray a few coats of clear on it to give it a good shine.
Old 01-12-2003, 07:51 AM
shocon2k
Did you NOT read the posts above this one?
Old 01-12-2003, 05:35 PM
VuN86
should taking off the paint be really hard? i was using rubbing alcohol and was scrubbing at the paint for like 10 mins and nothing happened what's up with this so i need to scrub harder and longer?
Old 01-12-2003, 06:03 PM
VuN86
ok there has got to be an easyier way of getting the paint off this i just spent 30mins scrubbing hard at this bodie and all i can get off is the hood part is there something else i could except rubbing alcohol?
Old 01-12-2003, 08:34 PM
Spanky's Avatar
Mr. Goop
i let mine soak in the rubbing alch. for about a half hour first. the hardest was to get the paint outa the fine lines/door jams etc...
Old 01-12-2003, 08:36 PM
VuN86
what did u do with the rest of the rubbing alcohol just dump it back in the bottle cause i don't want to waste it cause it's not mine
Old 01-12-2003, 08:46 PM
Spanky's Avatar
Mr. Goop
i dumped it out. it was blue after i cleand the car... a bottle of the stuff only costs a buck.
Old 01-12-2003, 08:47 PM
VuN86
o hehe i didn't know that
Painting a ZZ rody ZipZaps 3 11-07-2006 09:51 PM
Painting the body Rumiko12345 XMODS 1 02-23-2004 08:42 AM
Comparison.....Bit, Lxxx, Precious, Bensu....... DarkTari Bit Char-G / MicroSizers 3 02-22-2003 11:36 PM
Shen Vs. Precious sessiz10 Bit Char-G / MicroSizers 41 02-04-2003 02:14 PM
