Old 01-11-2003, 05:31 PM
crazydave's Avatar
Garage Rocker
Question Couple ??s about chargeing at 4 volts.
I have a clone that came with a separate charger that runs off of 3 AAAs. I tested it, and aparently the timer is taking exactly a half volt. It put out 3.94 when the individual batteries read 1.48, and 4.15 with a fresh set that were 1.55 a piece.
My first question is that i see people charge dual cells with 3-cells, so would 4.15 volts be enough to charge a car with dual cell, or do I still have to disconnect the timer? I realize it would be better, but is it necessary?
Also I know from running 1/10 scale that that higher voltage means faster discharge, and shorter run times. So I was wondering if charging at 4 volts would have a similar effect. I didn't know if it would cause the battery to take a higher voltage. I just know that the clone eats the Zip Zap for breakfast, even with a 2.6 in the Zip Zap. I initially assumed that was mostly due to gearing, but now I wonder if this is a factor
Dave
Crazy Dave's Crazy Car Gallery-It's crazy man, dig it.
Old 01-11-2003, 05:43 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
The ZipZap has a horrid PCB, with high resistance. I charge my 2-cell with four AAA's, runs just fine.
Old 01-11-2003, 05:56 PM
crazydave's Avatar
Garage Rocker
Yeah, so I've heard.
You mention a PCB mod for the Zz in your sig. Got a link or any info about that?
To put my original question in less rambling terms: Will these batteries take a higher voltage if they are hit with a higher voltage?
Thanks for any answers you might have.
dave
Old 01-12-2003, 01:56 AM
Riven Riven is offline
<-Buying Electromag Coils
The clone u are talking about sounds like a motorworks and they charger from it takes 3 AAAs. I have used it to charge my dual cell mod. i just do 2 or 3 consecutive charges.
Old 01-12-2003, 02:04 AM
krillin52's Avatar
krillin52 krillin52 is offline
PLOOP!
Send a message via AIM to krillin52
i have the same clone. and it kicked the crap outta my friends bullet clone. i think his was either a shen or a precious.. ne ways if you wanna see something real cool look for a thread started by Nefarious called "DUAL BATT DUAL MOTOR CLONE" or something like that.
Old 01-12-2003, 08:14 AM
crazydave's Avatar
Garage Rocker
Mine is called a Cannonball. It has a little oval holographic sticker, on the case, that says "ST" all over it, and crisscrossed checkered flags. I've noticed that many clones have that same sticker. Further proof they were manufactured in the same factory.
Interestingly enough, there is the spot for the charger on the controller. I could easily install it in my controller, but I'm just curious why they would decide to do some with the charger separate. I would think molding a separate case would add to the manufacturing cost, and I thought these guys were trying to cut cost at every corner.
Dave
Old 01-12-2003, 06:42 PM
scottyboyfun's Avatar
scottyboyfun scottyboyfun is offline
Im a cat, miow.
Send a message via Yahoo to scottyboyfun
Mayb they had a load of unused plastic boxes from another job,so they adapted them into a separate charging unit rather than throw them away?
So what do u lot think?
Post it!
Old 01-12-2003, 07:39 PM
Nathan's Avatar
Bad Driver
The PCB mod i found is the "New PCB mod" Thread on Bit Science. Warning- soldering required.
Old 01-12-2003, 08:58 PM
crazydave's Avatar
Garage Rocker
Yeah, I've found a couple mods since I asked that. Thanks though.
Don't worry about me soldering, I've been scratch building guitar effects lately, but I have to admit, I am intimidated by working with that itty bitty surface mount technology. Those resisistors are so tiny. You guys are insane working with that stuff.
Dave
Dual 9volt works but not 18 volts. redline724 XMODS Mods and Projects 20 06-16-2006 11:24 PM
how many volts can they take bitter being XMODS 6 03-07-2005 07:40 AM
12 Volts Pumped Thru Motor! johnrtse Bit Science 25 05-11-2003 01:09 PM
