i have a mini x full bearings 3x6 on the front and rear hub another (2) 3x6 in the diffs and on the outside ,i also installed mini z wheels front and back by removing the pins on the rear shaft insert the rear holder for the rims from a kyosho mini z diff kit gpm or what have you ,line the holes from the rim holder with the rear shaft hole and thread the screw it should hold....
